Touchscreen on MK808
    Hello, i am trying to use my mk808 as a carpc, i have a 7in capacitive touchscreen, image is showing perfectly, but the touch connects and works, but when you put you finger on screen it doesnt release. What i mean to say is, that when i touch a finger or even 2 it sees the input, but when i lift my finger it still thinks i am touch it, so if i put a touch in opposite corner of screen, cursor makes a line between those 2 touches. Does anyone know of a usb touchscreen driver that works properly for any version of android that we can compile into our roms? thanks in advance!!
    I found this threat about a similar subject that im hoping someone smarter than me can take a look at. http://www.trimslice.com/forum/viewtopic.php?t=481
    why not just buy a tablet i plan getting a tablet for each headset and somehow getting it in the headset of the car seat possiably even a wifi router for movies
      MAE24 - where did you get the touchscreen with the capacitive touch panel?
