Ways to find out whether your tv stick is cleanly shutdown is by Installing 'no-frill cpu.control' from play store. underclock your cpu. tick apply on boot.
Poweroff your unit
If its been turned off dirty. You will see a message with 'unclean' shutdown on the status bar.
To get a clean shutdown you will need to kill all apps. unmount filesystem before sync-ing the shutdown command. So far there are no apps that does this. Everyone will get a corrupted tv.stick eventually.
Im not a programmer myself so i cant help with.you people. the link i have above however will have scripts which.you can.compile yourself to remove the problem.
