WiFi adapter or mod for MK808B??
Hi, I bought a MK808B and was planning to use it mostly for YouTube and surfing the web from my TV, but my device has a really bad reception and slow internet speed. Is there a WiFi adapter I can purchase that will easily work for my device? Or a mod or something to fix this? I found lots of post but none for the 808b, I'm not sure if it makes any difference, but I'm a noob and I would appreciate some help!Last edited by kickokim; 01 February 2013, 01:52. -
Originally posted by kickokim View PostHi, I bought a MK808B and was planning to use it mostly for YouTube and surfing the web from my TV, but my device has a really bad reception and slow internet speed. Is there a WiFi adapter I can purchase that will easily work for my device? Or a mod or something to fix this? I found lots of post but none for the 808b, I'm not sure if it makes any difference, but I'm a noob and I would appreciate some help!
Originally posted by kickokim View PostOr a mod or something to fix this?
basically if you open up your 808B, you'll see an ANT (antenna) pin and a GND (ground).
Dont worry about the ground, but just connect some metal to the ANT (a wire or something). That should improve the reception.
Please report back if it worked for you.
cheers
Originally posted by neomode View PostFor the best Result take a old Antenna from a Router and connect it to it.
Or you can buy one with a fma socket to mount it on the Stick.
Neomode
AW: WiFi adapter or mod for MK808B??
I dont think it is your W-LAN Adpater. I think it is the Network.
Get this App from App Store Wifi Analyzer and lock with how many W-LANś you share your Channel.
Than change your Chanel to a free one and you will get better Wlan File Transfer.
Gesendet von meinem A210 mit Tapatalk 2
Originally posted by neomode View PostI dont think it is your W-LAN Adpater. I think it is the Network.
Originally posted by kickokim View PostYou were right, the problem isn't the Wifi chip. I just connected to my 3g network using my phone with tethering and it works like a charm! But I can-t understand why it wont work with my router. The radio channel looks clean and all my other devices work with it!
The signal strength is OK (-60dBm), but the connection speed is only 1-5Mbps. Actually it connects to 54Mbps but it drops immediately to 2Mbps. There is no other network on the same 2.4G channel except my router.
I also shared the 3G connection of my phone over WiFi and it works at 65Mbps at 2 meters distance.
BUT, if I put my phone next to the router, then the link speed also drops to 5Mbps.
So, it has to be fu**ing wifi antenna of the stupid box.
I ordered this antenna and this USB ethernet adapter, just in case.
linksys antena replacemet but link speed still shows 2Mbps
Originally posted by underdog View Postyes, indeed. It seems the only solution to the wifi issue is to assemble a decent antenna.
I've done it and the improvement is huge in terms of link speed - from 1-2Mbps up to 65 Mbps. Connection speed of 150Mbps is still not possible, but at least I could use 30Mbps download speed.
hat channel are you using
There are currently 1713 users online. 2 members and 1711 guests.
