How to downclock the GPU Mali-400 ??
    is it possible to downclock the gpu mali 400?
    when i try to downclock using android tuner i have 2 options CPU0 and CPU1
    CPU0 is the gpu mali?
    CPU1 is the real CPU?
    the program does not let me downclock the cpu0 at one speed and the cpu1 at another speed. In other words if you set cpu1 at 800mhz the system sets cpu0 at 800mhz also
    if both are clocked at 1.2Ghz
    total score 8461
    cpu 3033
    gpu 3172
    if both are clocked at 816mhz
    total score 6966
    cpu 2160
    gpu 2986
    if both are clocked at 252mhz
    total score 3464
    cpu 640
    gpu 2031
    so the gpu speed is very high even at the lowest cpu0 and cpu1 clocks
    i really dont understand
    Let me ask what CPU you got ?
    If you have a RK3066 than you have a Dualcore CPU.
    This way it show´s CPU 0 & 1.
    I dont know a way to downspeed a GPU on Android.
    Neomode
