HiMedia Q5 Android Media Player Review
    HiMedia is usually known for their Realtek based media players but recently they have started producing Android based players. The Realtek players are well known for their high compatibility with all kinds of video and audio formats. When making the switch over to Android, HiMedia has put a lot of effort into making sure that their Android players perform as well as their Realtek players when it comes to playback support.
    HIMEDIA Q5 ANDROID MEDIA PLAYER TECHNICAL SPECIFICATIONS
    > OS - Android 4.0.3 (Ice Cream Sandwich)
    > Chipset - Hisilicon 3716C, ARM Cortex A9 1GHz
    > Memory - 1GB DDR3
    > Built-in Storage- 4GB (2GB for OS, 2GB available space)
    > Network - WiFi 802.11 b/g/n
    > Additional Storage - SD / SDHC / MS PRO card reader
    > Video Formats - TS, M2TS, TP, TRP, MKV, MP4, AVI, RM, RMVB, WMV, ASF, FLV, VOB, DAT, MPG, MPEG
    > Audio Formats - MP3, WMA, WAV, APE, AAC, FLAC, MKA
    > Video/Audio Output - HDMI (up to 1080P), Composite Audio/Video, Y/Pb/Pr Video, S/PDIF Coaxial (digital audio), S/PDIF Optical TOSLink (digital audio)
    > USB Ports - 3 USB 2.0 Host
    > SATA Ports - 1 SATA interface for SATA HDD
    > Size - 170 x 115 x 24.5 mm
    > Weight - 500 g
    Quad-Core Android Mini PC Buying Guide | Must Have Apps for Android Mini PC
    Androydz.com - Everything Android plus a little more
    TopChinaTablets.com - China Tablet Ultimate Guide
    GetdatGadget.com - Gadgets That You Want
    Nice machine will give Minix Neo X5 a run for the money !
      just got mine yesterday - really nice device. brushed aluminium. lots of connectivity (all you could wish for - even SATA). Live chinese TV with a remote control for who needs it (believe it's a custom app - quite impressed with the easyness it works)
        root
        in case someone needs to root this amazing little box (love the AC3 and smooth fast forward in movies)
        adb connect %var%:5555
        adb root
        adb remount
        adb push su /system/bin
        adb push Superuser.apk /system/app
        adb shell chmod 4755 /system/bin/su
        replace %var% with the ipadress of your q5.
        download the root toolkit (adb program and superuser.apk) from here http://pan.baidu.com/share/link?shar...5&uk=520615393
          pictures of the device and its nice aluminium case can be found here (if you open in google chrome it auto-translates from chinese)
            adb root
            adb remount
            Picaye: are you shure this are the exact steps?
            shouldnt be conneted thought usb?
            abd of the device was able to accept connections using wifi or Ethernet connection?
              Firmwares:
              1.0.3 (2012-11-06)
              Changelog
              The Android system platform
              1) New openGL driver, improve graphics performance and accelerate the speed of webpage browser
              2) Fix the but that NTP sometimes fail to get the time
              3) Added support for remote operation of the Chinese input method
              4) Modify the network DNS refresh mechanism in network anomaly
              5) Add new module such as Google Maps, Google contact modules,
              6) Built-in China Android Market.
              7) Improve the stability of AirPlay, and change the UI of AirPlay
              8) Fix the Q input issue of the HiControl
              9) Fix the Volume of work some time
              Media Playback
              1) Add external subtitle supported for BDISO and Blu-ray directory (SRT, ASS, SSA )
              2) Improve the performance of BDISO Playback
              3) Speed up the loading time of BDMV and BDISO
              4) Add One new format of Blu-ray PGS
              5) Fix A/V sync issue on some VC1 video
              6) Fix one bug of PGS subtitle display
              7) Add LPCM 7.1 support ( Amplifer need)
              8) optimize the performance of DTS-HDMA
              9) Fix one bug on 59.94, 60Hz source
              External Subtitle file for BDMV and BDISO
              The ISO file
              Afanda.Iso
              Afanda.Srt
              The BDMV directory
              Speed and passion 5/BDMV
              Speed and passion 5/speed and passion 5.srt
              HiControl 1.0.3
              1) Add phone input method for Hicontrl
              2) Add phone voice input method
              3) Fix the q issue of HiControl
              4) Improve the HiControl device finding
              5) Add online upgrade for HiControl
              6) can be installed from apk.hinavi.cn
              Firmware download
              Q5 1.0.4(2012-11-30)
              Q5 1.1.1 ( 2012-12-27) (THIS IS THE LATEST)
                Here it is the CPU Spec sheet.
                Download: http://www.hisilicon.com/engdownload...0DataBrief.rar
                Some of the important stuff shown on this doc are:
                Key Specifications
                CPU
                * High-performance core solo ARM Cortex A9 processor
                * Mechanism of providing dual-core services, processing
                capability of 2500 MIPs
                * Built-in I-cache, D-cache, and L2 cache
                * Hardware JAVA acceleration
                * Floating-point coprocessor
                Memory Control Interface
                * Double-data rate 2 (DDR2)/DDR3 interface
                − Maximum memory of 1 GB
                − 32-bit memory width
                * Serial peripheral interface (SPI) flash
                * NAND flash
                Video Decoding
                * H264 MP, HP@ level 4.1
                * MPEG1
                * MPEG2 MP@HL
                * MPEG4 SP@ levels 0–3 and ASP@ levels 0–5
                * MPEG4 short header format (H.263 baseline)
                * Divx4–6
                * AVS baseline@ level 6.0
                * H.263
                * RealVideo8/9/10
                * VC-1 AP
                * Decoding capabilities of 1080p (30 fps) and 576i (25 fps) or
                480i (30 fps)
                * Video post-processing such as denoising and deblocking
                Picture Decoding
                * Full high-definition JPEG decoding, a maximum of 64
                megapixels
                * PNG decoding, a maximum of 64 megapixels
                Audio/Video Encoding
                * H.264/MPEG-4 video encoding, a maximum of
                720x576@25 fps
                * JPEG encoding
                * Variable bit rate (VBR) and constant bit rate (CBR) modes
                for video encoding
                * 1-channel audio encoding
                * Echo cancellation
                Audio Decoding
                * MPEG L1/L2 decoding
                * Dolby digital and Dolby digital plus decoding
                * AC3 transparent transmission
                * Down mixing
                * Resampling
                * 2-channnel sound mixing
                * Intelligent volume control
                TS Demultiplexing/PVR
                * 3-channel transport stream (TS) inputs including 1-channel
                intermediate frequency (IF) input
                * One built-in quadrature amplitude modulation (QAM)
                module
                * 1-channel QAM loopback output
                * A maximum of 96 packet ID (PID) filters
                * Full-service personal video recorder (PVR)
                * Recording of scrambled and non-scrambled streams
                * Advanced encryption standard (AES), data encryption
                standard (DES), or triple data encryption standard (3DES)
                data encryption
                * Content protection for universal serial bus (USB) devices
                * Content protection for serial advanced technology
                attachment (SATA) or external serial advanced technology
                attachment (eSATA) hard disks
                Security Processing
                * Advanced security features
                * One-time programmable (OTP) and chip ID
                Graphics Processing
                * Enhanced full-hardware 2D graphics acceleration engine
                * Full-hardware anti-aliasing and anti-flicker
                * Full-hardware 3D graphics processing unit (GPU)
                acceleration engine
                * Standard OpenGL ES 2.0/1.1/1.0 OpenVG 1.1 interfaces
                Display Processing
                * 2-layer on-screen display (OSD)
                * 16-bit or 32-bit color depth
                * Two background layers and two video layers
                * 1920-pixel width for each layer
                * Image enhancement
                Audio/Video Interface
                * Output norm of PAL, NTSC, or SECAM and force standard
                conversion
                * Aspect ratio of 4:3 or 16:9, force aspect ratio conversion,
                and scaling
                * 1080p 50(60)/1080i/720p/576p/576i/480p/480i outputs
                * Receiving of standard-definition and high-definition signals
                * Simultaneous output of high-definition and
                standard-definition signals from the same source or different
                sources
                * xvYCC (IEC 61966-2-4) standard for color gamut
                * Digital video interface
                − High-definition multimedia interface 1.4 (HDMI 1.4)
                with high-bandwidth digital content protection 1.2
                (HDCP 1.2)
                − One BT.656/601 or BT.1120 video input (VI) interface
                Analog video interface
                − One composite video broadcast signal (CVBS) interface
                − One YPrPb interface
                − One S-Video interface
                − Six built-in video digital-to-analog converters (DACs)
                − Configurable output interface
                − Macrovision and vertical blanking interval (VBI)
                * Audio interface
                − Left-audio and right-audio channels (RCA output
                interface with low impedance and imbalance)
                − Sony/Philips digital interface (SPDIF)
                − One built-in audio DAC
                − One digital audio input/audio output (AI/AO) interface
                (pulse code modulation (PCM) with multiple time slots)
                Peripheral Interface
                * One eSATA/SATA interface (with integrated physical layer
                (PHY)), supporting 1.5 Gbit/s or 3.0 Gbit/s rate
                * One peripheral component interconnect express (PCIe)
                interface (with integrated PHY)
                * Two USB 2.0 host ports (with integrated PHY)
                * One 8-bit secure digital input/output (SDIO) interface
                * Two 10/100 Mbit/s adaptive Ethernet ports supporting the
                2-layer or 3-layer switch function or one 10/100 Mbit/s or
                10/100/1000 Mbit/s adaptive Ethernet port
                * Three universal asynchronous receiver transmitter (UART)
                interfaces
                * Two smart card interfaces, supporting T0, T1, and T14
                protocols
                * One infrared (IR) receiver processor and two input
                interfaces
                * One light emitting diode (LED) and keypad control interface
                * Three inter-integrated circuit (I2C) interfaces
                * 13 groups of general-purpose input/output (GPIO) interfaces
                Others
                * Fast startup
                * Downloading and running of boot programs through the
                serial port
                * Passive standby and low-power consumption
                * Entire standby power less than 1 W
                * Typical entire power less than 9 W in operating mode
                * 756-pin plastic ball grid array (PBGA) package with 31 mm
                x 31 mm dimensions and 0.8 mm pitch
                Looks better thant the himedia q4.
                  To un pack the rom for tweaking you will need to do the following.
                  1 - Download the rom. into your linux machine or linux virutal pc
                  2 - unzip it you will get all the img files from the rom.
                  sample:
                  root@debian:/home/tatubias/HiMediaQ5/unpacked# ls -la
                  total 281284
                  drwxr-xr-x 4 root root 4096 Mar 26 13:07 .
                  drwxr-x--- 3 tatubias tatubias 4096 Mar 26 13:04 ..
                  -rw-r--r-- 1 root root 8192 Feb 29 2008 baseparam.img
                  -rw-r--r-- 1 root root 65536 Feb 29 2008 bootargs.img
                  -rw-r--r-- 1 root root 4320524 Feb 29 2008 boot.img
                  -rw-r--r-- 1 root root 427976 Feb 29 2008 fastboot.img
                  -rw-r--r-- 1 root root 58997 Feb 29 2008 logo.img
                  drwxr-xr-x 3 root root 4096 Mar 26 13:04 META-INF
                  -rw-r--r-- 1 root root 3492444 Feb 29 2008 recovery.img
                  -rw-r--r-- 1 root root 279166968 Feb 29 2008 system.img
                  -rwxr-xr-x 1 root root 8236 Mar 19 17:37 unyaffs
                  -rwxr-xr-x 1 root root 34194 Mar 19 09:47 unyaffs2
                  -rw-r--r-- 1 root root 107400 Feb 29 2008 userdata.img
                  3 - To un pack the system.img you will need to do the following.
                  a) in your linux pc or virtual pc download unyaffs2 - Download yaffs2 Utility
                  b) you will get a latest.tar.gz file
                  c) un pack it
                  d) enter the directory that was un packed and compile the application todo that you need only to run make command.
                  e) copy the unyaffs2 and mkyaffs2 to the directory that you have unziped the rom.
                  f) run: (go to the directory that you have the system.img and unyaffs2 files)
                  mkdir system
                  ./unyaffs2 -p4096 -s200 system.img ./system
                  g) now you have unpacked the system.img now you can start tweaking the rom.
                  root@debian:/home/tatubias/HiMediaQ5/unpacked/system# ls -la
                  total 84
                  drwxr-xr-x 15 root root 4096 Mar 26 13:08 .
                  drwxr-xr-x 4 root root 4096 Mar 26 13:07 ..
                  drwxr-xr-x 2 1005 1005 4096 Dec 27 21:47 app
                  drwxr-xr-x 2 1005 1005 12288 Dec 27 08:13 bin
                  -rwxr-xr-x 1 1005 1005 1673 Dec 27 07:34 build.prop
                  drwxr-xr-x 5 1005 1005 4096 Dec 21 07:38 busybox
                  drwxr-xr-x 11 1005 1005 4096 Dec 27 08:14 etc
                  -rwxrwxrwx 1 root root 158 Dec 31 1969 .flash
                  drwxr-xr-x 2 1005 1005 4096 Dec 27 07:45 fonts
                  drwxr-xr-x 2 1005 1005 4096 Dec 27 08:11 framework
                  drwxr-xr-x 8 1005 1005 12288 Dec 27 08:15 lib
                  drwxr-xr-x 3 1005 1005 4096 Dec 27 07:36 media
                  drwxr-xr-x 3 1005 1005 4096 Dec 27 07:14 samba
                  drwxr-xr-x 3 1005 1005 4096 Dec 27 07:36 tts
                  drwxr-xr-x 8 1005 1005 4096 Dec 27 07:43 usr
                  drwxr-xr-x 3 1005 1005 4096 Dec 27 07:38 vendor
                  drwxr-xr-x 2 1005 1005 4096 Dec 27 08:12 xbin
                  if you want to repack the rom you will try the following command.
                  (rename the original system.img to systemoriginal.img to avoid deleting it)
                  ./mkyaffs2 -p4096 -s200 ./system system.img
                  This command will get all the files in ./system and will pack them into a image called system.img
                    How to upgrade from setup menu
                    2012-9-1
                    1) Download the version according to your product Q5 update.zip
                    2) put the "update.zip" into USB disk (Q2 use update_Q2.zip, Q4 use update_Q4.zip)
                    3) goto setup--system upgrade, click "SDA" or SDB
                    4) Q5 will reboot and entering the upgrade mode, there will be a ROBOT screen
                    6. Wait for the smart tv box to complete the firmware update. Please be patient as it may take around 5 minutes to complete.
                    7.Box will auto reboot after upgrade is finished
                      Recovery Mode Update:
                      1.Download the new firmware and place the firmware onto the ROOT directory of a USB drive.
                      2.Plug the USB drive into an empty USB HOST on the smart tv box.
                      3.With the smart tv box turned off,use a paper clip or tooth pick to press and hold the small pinhole restore button on the smart tv box.
                      4.While pressing the restore button,turn on the smart tv box. Continue to hold the restore button for 5 more seconds,then release it.
                      5.The restore mode will begin upgrading the firmware from the USB drive as below:
                      7. After upgrading, pls go to SETUP to check the firmware version.
                        FAQ
                        Q:What is HiControl?
                        A: HiControl is an App developed by HiMedia.With this App,your Android smart-phone can be transformed to Touch-screen and Remote-controller for HiMedia smart TV box.Take control on your Android smart-phone while the action unfolds on your widescreen TV. With the Gravity Sensing of your smart phone, you even can play games such as Crazy Snow Ball on your HDTV.
                        Q:What is HiShare?
                        A:HiShare is an App developed by HiMedia.It can let you wirelessly share media file(video/audio/photo) from your Android smart-phone or pad to your HDTV via HiMedia smart TV box.
                        Q:Does Q5 support AirPlay functions?
                        A:Yes.AirPlay lets you wirelessly stream content from your iPhone,iPad or iPod touch to your HDTV via the Q5 smart TV box. More detail about AirPlay please check www.apple.com/airplay. (The Q5 support music,photo and video share).
                        Q:Does Q5 support DOLBY and DTS?
                        A:Yes, Q5 supports DOLBY and DTS very well.
                        HiControl
                        2012-11-24
                        HiContol: It is an App developed by HiMedia.With this App,your Android smart-phone can be transformed to Touch-screen and Remote-controller for HiMedia smart TV box.Take control on your Android smart-phone while the action unfolds on your widescreen TV. With the Gravity Sensing of your smart phone, you even can play games such as Crazy Snow Ball on your HDTV. Use your Android smart-phone to download the HiContorl app from http://apk.hinavi.cn/en.html now.
                        HiShare:It is an App developed by HiMedia.It can let you wirelessly share media file(video/audio/photo) from your Android smart-phone or pad to your HDTV via HiMedia smart TV box. Use your Android smart-phone to download the HiShare app from http://apk.hinavi.cn/en.html now.
                          Here i have gathered some youtubes videos of the himedia q5 device
                          there are lot more video fo himedia q5 on youtube. so you can search them.
                            Re: HiMedia Q5 Android Media Player Review
                            Hi im adding new video tutorial that shows you how to use the devices and you can see all the good stuff that it brings with.
                            Sent from my MOMO11 四核 using Tapatalk 2
