Is DTS decoding unique to the MK808??
    Ive installed finless 1.6 btw. Do all androind sticks decode DTS using their stock player or is it a feature of finless 1.6? Ive read online how DTS decoding has been remove from almost all android video players. But I can play 1080p with DTS just fine on my MK808. Im getting a MINX G4 to replace MK808 due to wifi being dead on the MK808, worried G4 wont be able to decode DTS and 1080p mkv.
    bump!
      ill take the mk808 off your hands with bad wifi lol
      all you need to do is buy a $3 usb ethernet adapter and your back online
      way cheaper to do that instead of buying a new stick
      not sure about dts im not even sure what it is the only device i have is mk808 and i have a usb audio device that i think mentions dts so it should work on another stick
