After turning off the power connector blue diode.
    Hello
    I UG 802 and recently I've uploaded a finless custom ROM version 1.7
    Everything worked fine until one day I accidentally turned off the device by pressing the reboot.
    And since then (maybe it's a coincidence) me after disconnecting power and subsequent power facility of nenajede.
    I have several times to eject and insert the connector and then catches it. I do not know if anything goes but it pisses me off and I tried different cables and even power from the computer and from the adapter from the wall outlet to what was and still is broken.
    I do not know what it is and if you have any advice let me know.
    Thank you very much.
    Your power supply might be broken.
