[help] Cant get usb ethernet to work
    Ive got a usb ethernet adaptor by pluscom chipset infineon ADM 8515 that i got from here
    http://www.****.co.uk/itm/USB-ver2-0...ccd84e2&_uhb=1
    Whenever I enable ethernet in options it turns off again after 3 seconds.
    im using finless 1.6. not even the connected light on my router
    what am i doing wrong? Really thinking of giving up on the 808 soon!
    Got the same issue with the wi-fi option, says turning on and then automatically switches itself off.
    I'm just gonna reroll back to all the original stock firmware and see if this fixes it and then find out what the issue is fromt here hopefully.
    Annoying!
      please let me know if the stock fixes anything. but think ill stick with finless for now.
      anyone got any ideas?
        driver issue. The kernel of your ROM probably doesn't have the driver for you chipset included (adm8515)
        You should find a compiled version of your driver and run insmod "modulename.ko" in terminal emulator to enable it.
        If I understood well the instrcution I got yesterday for a similar problem, you could then add it in init.d as a script to make this driver load everytime you boot your mk808.
        You need to have the exact driver for your hardware if you want it to work properly.
        Last resort would be to find a ROM with the driver pre-loaded... good luck on that one.
        I got a similar problem with my usb ethernet adapter which is suppose to have chipset mcs7832. I loaded a driver that let me turn ON ethernet but it doesn't connect at all to the router. probably the wrong driver... gonna open the device tonight to see the exact chipset inside.
          what do you mean by a compiled version?
          I have a cd with it, which includes the linux driver ... the files are...
          linuxdrv.txt
          makefile_16.txt
          pegasus.c
          pegasus.h
            pegasus.c
            THIS file should be the source code of the driver.
            In a linux OS like ubuntu you could "compile" it using make command
            Android doesn't let you do that. At least it's not that easy. If I understood correctly the documentation i'm reading these days, you need to compile the kernel in an external environment. this being said, it's more easy to find a pre-compile version of your driver which may be called pegasus.ko
            then you could run insmod pegasus.ko into an terminal emulator to add the module to your current kernel.
            this need to be done every time you boot or creating a script that would do it for you at every boot.
            you should read this post as it concern your problem but with a different chipset : http://www.freaktab.com/showthread.p...light=ethernet
            the process for your chipset would be similar but with a different driver
              thanks for all your help. tried very hard but cant complie it, i think its far above my ability.
              Its uploaded here if anyone is kind enough to be able to compile it for me
              The versions of pegasus.ko ive found dont seem to be quite the right version.
                Here are the steps tha help me understand my problem
                1) unplug your device
                2) run logcat -c (terminal)
                3) run logcat (terminal)
                4) plug device
                5) check logcat output about eternet
                6) paste appropriate lines here
                My last line about ethernet ended with dhcp request error: dhcp result property was not set
                So at least i know my system found the device but is unable to connect to the router
                P.S : thanks to bob for these command
                It point in the right direction for my searches
                  nothing jumps out at me as being a problm, but not sure... all i can see network related is this which appeared when i plugged in the ethernet adaptor....
                  Code:
                  W/Vold    (   78): subsystem found in netlink event
                  D/Vold    (   78): usb, 1
                  D/Vold    (   78): == current usb device: 07A6/8515 ===
                  full log below
                  Code:
                  u0_a68@android:/ $ logcat -c
                  --------- beginning of /dev/log/main
                  D/LatinKeyboardView(  453): ##----- keycout = 39 ------@@@
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 11% free 6353K/7111K, paused 2ms+8ms, total 38ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 432K, 11% free 6338K/7111K, paused 19ms+2ms, total 42ms
                  D/dalvikvm(  453): GC_CONCURRENT freed 691K, 12% free 8377K/9479K, paused 16ms+2ms, total 49ms
                  D/dalvikvm(  453): GC_CONCURRENT freed 705K, 12% free 8376K/9479K, paused 13ms+2ms, total 60ms
                  D/dalvikvm(  453): GC_CONCURRENT freed 691K, 12% free 8376K/9479K, paused 16ms+2ms, total 44ms
                  D/dalvikvm( 1104): GC_CONCURRENT freed 418K, 17% free 7040K/8391K, paused 17ms+5ms, total 47ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 433K, 11% free 6341K/7111K, paused 17ms+2ms, total 46ms
                  D/dalvikvm(  453): GC_CONCURRENT freed 691K, 12% free 8377K/9479K, paused 17ms+3ms, total 50ms
                  D/dalvikvm(  453): GC_CONCURRENT freed 691K, 12% free 8376K/9479K, paused 14ms+2ms, total 45ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 410K, 11% free 6346K/7111K, paused 3ms+6ms, total 30ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 11% free 6346K/7111K, paused 12ms+4ms, total 41ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 432K, 11% free 6345K/7111K, paused 13ms+5ms, total 43ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 11% free 6345K/7111K, paused 17ms+2ms, total 39ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 11% free 6345K/7111K, paused 16ms+2ms, total 43ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 416K, 11% free 6346K/7111K, paused 12ms+3ms, total 39ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 11% free 6346K/7111K, paused 13ms+2ms, total 40ms
                  D/dalvikvm(  453): GC_CONCURRENT freed 691K, 12% free 8376K/9479K, paused 15ms+3ms, total 40ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 11% free 6346K/7111K, paused 15ms+2ms, total 43ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 446K, 11% free 6345K/7111K, paused 6ms+2ms, total 40ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 11% free 6345K/7111K, paused 13ms+2ms, total 44ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 11% free 6345K/7111K, paused 15ms+2ms, total 54ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 406K, 11% free 6347K/7111K, paused 11ms+2ms, total 24ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 432K, 11% free 6347K/7111K, paused 15ms+2ms, total 42ms
                  D/AudioHardwareALSA(   86): Audio exiting sandby will open audio device
                  I/ALSAModule(   86): open devices: 0x2
                  I/ALSAModule(   86): Initialized ALSA PLAYBACK device AndroidPlayback_Speaker_normal
                  D/dalvikvm( 2171): GC_CONCURRENT freed 317K, 10% free 6447K/7111K, paused 13ms+12ms, total 46ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 462K, 11% free 6445K/7239K, paused 16ms+1ms, total 44ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 460K, 11% free 6447K/7239K, paused 15ms+2ms, total 39ms
                  --------- beginning of /dev/log/system
                  I/ActivityManager(  256): START {cmp=jackpal.androidterm/.TermPreferences u=0} from pid 2171
                  D/dpt     (  256): setPerformanceMode: 0 ;value: 0
                  D/dalvikvm(  256): GC_FOR_ALLOC freed 245K, 14% free 10019K/11591K, paused 43ms, total 45ms
                  I/dalvikvm-heap(  256): Grow heap (frag case) to 10.195MB for 124216-byte allocation
                  D/dalvikvm(  256): GC_FOR_ALLOC freed 14K, 14% free 10126K/11719K, paused 40ms, total 40ms
                  W/Sidekick_GmmLocationProviderImpl( 1950): Unable to bind to GMM NLP
                  W/ActivityManager(  256): Unable to start service Intent { act=com.google.android.location.internal.GMM_NLP (has extras) }: not found
                  W/InputMethodManagerService(  256): Focus gain on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@42657268 (uid=10068 pid=2171)
                  W/Resources( 2171): Converting to string: TypedValue{t=0x10/d=0x1 a=2 r=0x7f070000}
                  I/InputDispatcher(  256): Dropping event because there is no touched window.
                  D/dalvikvm( 2171): GC_CONCURRENT freed 269K, 9% free 6639K/7239K, paused 11ms+2ms, total 43ms
                  I/ActivityManager(  256): Displayed jackpal.androidterm/.TermPreferences: +348ms
                  D/dalvikvm(  371): GC_CONCURRENT freed 809K, 58% free 8532K/20103K, paused 16ms+2ms, total 59ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 499K, 12% free 6594K/7431K, paused 15ms+2ms, total 39ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 417K, 12% free 6597K/7431K, paused 15ms+2ms, total 38ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 291K, 10% free 6714K/7431K, paused 3ms+2ms, total 28ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 434K, 11% free 6713K/7495K, paused 11ms+1ms, total 26ms
                  W/InputMethodManagerService(  256): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@4268f380 attribute=null
                  D/dalvikvm( 2171): GC_CONCURRENT freed 432K, 11% free 6713K/7495K, paused 12ms+6ms, total 32ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 553K, 12% free 6610K/7495K, paused 16ms+2ms, total 51ms
                  D/dalvikvm(  256): GC_FOR_ALLOC freed 170K, 15% free 10021K/11719K, paused 35ms, total 35ms
                  D/dalvikvm( 2171): GC_FOR_ALLOC freed 186K, 11% free 6677K/7495K, paused 11ms, total 11ms
                  I/InputAttributes(  453): InputType.TYPE_NULL is specified
                  D/dalvikvm(  453): GC_CONCURRENT freed 726K, 12% free 8376K/9479K, paused 4ms+3ms, total 71ms
                  D/dalvikvm(  453): GC_CONCURRENT freed 677K, 12% free 8377K/9479K, paused 12ms+7ms, total 40ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 470K, 12% free 6610K/7495K, paused 3ms+2ms, total 26ms
                  D/AudioHardwareALSA(   86): AudioStreamOutALSA::standby().....
                  D/dalvikvm( 2171): GC_CONCURRENT freed 596K, 15% free 6431K/7495K, paused 7ms+2ms, total 34ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 402K, 15% free 6432K/7495K, paused 14ms+2ms, total 38ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 431K, 15% free 6440K/7495K, paused 18ms+13ms, total 86ms
                  D/dalvikvm(  371): GC_CONCURRENT freed 763K, 58% free 8528K/20103K, paused 5ms+3ms, total 38ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 432K, 15% free 6432K/7495K, paused 13ms+1ms, total 42ms
                  D/dalvikvm(  371): GC_CONCURRENT freed 750K, 58% free 8527K/20103K, paused 17ms+2ms, total 54ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 403K, 15% free 6432K/7495K, paused 15ms+1ms, total 41ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 392K, 15% free 6443K/7495K, paused 13ms+16ms, total 51ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 413K, 15% free 6434K/7495K, paused 5ms+1ms, total 28ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 417K, 15% free 6434K/7495K, paused 7ms+1ms, total 39ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 403K, 15% free 6435K/7495K, paused 16ms+1ms, total 47ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 402K, 15% free 6435K/7495K, paused 15ms+4ms, total 45ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 403K, 15% free 6434K/7495K, paused 12ms+4ms, total 38ms
                  E/Lights  (  256): write_int failed to open sys/class/leds/rk29_key_led/brightness
                  V/BackgroundService( 1767): onCreate
                  E/su      ( 2229): sudb - Opening database
                  E/su      ( 2229): sudb - Database opened
                  E/su      ( 2229): sudb - Database closed
                  D/AndroidRuntime( 2232):
                  D/AndroidRuntime( 2232): >>>>>> AndroidRuntime START com.android.internal.os.RuntimeInit <<<<<<
                  D/AndroidRuntime( 2232): CheckJNI is OFF
                  I/AndroidRuntime( 2232): JNI options: '-Xjniopts:warnonly'
                  D/dalvikvm( 2232): Unable to stat classpath element '/system/framework/filterfw.jar'
                  D/dalvikvm( 2232): Trying to load lib libjavacore.so 0x0
                  D/dalvikvm( 2232): Added shared lib libjavacore.so 0x0
                  D/dalvikvm( 2232): Trying to load lib libnativehelper.so 0x0
                  D/dalvikvm( 2232): Added shared lib libnativehelper.so 0x0
                  D/AndroidRuntime( 2232): Calling main entry [URL="http://com.android.commands.am.Am"]com.android.commands.am.Am[/URL]
                  D/AndroidRuntime( 2232): Shutting down VM
                  D/dalvikvm( 2232): GC_CONCURRENT freed 99K, 88% free 492K/4096K, paused 1ms+0ms, total 6ms
                  D/su      ( 2229): 10070 be.ppareit.hidebar_demo executing 0 /system/bin/sh using shell /system/bin/sh : sh
                  I/RootTools v2.4( 1767): [relatime, rw] AND rw
                  D/dalvikvm( 1767): GC_CONCURRENT freed 390K, 11% free 6106K/6791K, paused 12ms+1ms, total 29ms
                  D/dalvikvm( 1767): WAIT_FOR_CONCURRENT_GC blocked 6ms
                  I/RootTools v2.4( 1767): [ro, relatime] AND ro
                  V/BackgroundService( 1767): onStartCommand
                  D/dalvikvm( 2171): GC_CONCURRENT freed 388K, 15% free 6444K/7495K, paused 16ms+3ms, total 42ms
                  D/dalvikvm(  371): GC_CONCURRENT freed 680K, 58% free 8590K/20103K, paused 2ms+2ms, total 32ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 402K, 15% free 6445K/7495K, paused 15ms+1ms, total 42ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 403K, 15% free 6446K/7495K, paused 13ms+2ms, total 41ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 418K, 15% free 6445K/7495K, paused 19ms+2ms, total 53ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 417K, 15% free 6445K/7495K, paused 18ms+2ms, total 55ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 329K, 14% free 6520K/7495K, paused 2ms+2ms, total 28ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 391K, 14% free 6520K/7495K, paused 13ms+2ms, total 33ms
                  D/dalvikvm( 2171): GC_CONCURRENT freed 402K, 13% free 6524K/7495K, paused 12ms+3ms, total 38ms
                    Have you run insmod yourmodulehere.ko following instructions found here:http:// http://www.freaktab.com/show...light=ethernet
                    Before plug-in your device ?
                    If so it appear its not the good driver you will need another one
                    Try to plug your device into an ubuntu machine if you can get one and see what driver it uses.
                    BTW try shutting all proccess down on your system before running logcat
                    This way the log will be easier to read
                      sorry. i thought you ment run the logcat instead to check out the device.
                      i havent packaged the driver because i cant work out how to do it, and i cant find an exact version already packaged
                        okay, ive got pegasus.ko installed. got it to the point where it turns on the ethernet in settings but doesnt find an ipaddress and the router light doesnt come on. will try to get a logcat soon
                          cant get a logcan to you because to do that i'd have to run it without my wireless keyboard, and if i turn off wifi i cant connect to remote control. ive ordered a otg adaptor so i can have both my keyboard and my adaptor plugged in at same time and will get a log in a couple of days when it arrives
                            When ur ready
                              Okay. heres my log, still not working
                              Code:
                              02-09 11:54:56.255 D/dalvikvm(2681): GC_CONCURRENT freed 766K, 15% free 8390K/9799K, paused 12ms+9ms, total 66ms
                              02-09 11:54:56.535 D/dalvikvm(403): WAIT_FOR_CONCURRENT_GC blocked 0ms
                              02-09 11:54:56.565 D/dalvikvm(403): GC_EXPLICIT freed 209K, 11% free 6614K/7431K, paused 2ms+3ms, total 30ms
                              02-09 11:54:56.685 D/dalvikvm(258): WAIT_FOR_CONCURRENT_GC blocked 0ms
                              02-09 11:54:56.765 D/dalvikvm(258): GC_EXPLICIT freed 244K, 19% free 10710K/13127K, paused 4ms+6ms, total 80ms
                              02-09 11:54:57.385 D/dalvikvm(2681): GC_CONCURRENT freed 722K, 15% free 8384K/9799K, paused 14ms+15ms, total 70ms
                              02-09 11:54:58.465 D/dalvikvm(2681): GC_CONCURRENT freed 727K, 15% free 8376K/9799K, paused 21ms+5ms, total 68ms
                              02-09 11:54:59.275 W/Vold    (79): subsystem found in netlink event
                              02-09 11:54:59.275 D/Vold    (79): usb, 1
                              02-09 11:54:59.275 D/Vold    (79): == current usb device: 07A6/8515 ===
                              02-09 11:54:59.285 W/Vold    (79): subsystem found in netlink event
                              02-09 11:54:59.285 D/Vold    (79): usb, 1
                              02-09 11:54:59.445 D/PppoeService(258): onUEvent() : get uevent : '{SUBSYSTEM=net, DEVPATH=/devices/platform/usb20_host/usb2/2-1/2-1:1.0/net/eth0, SEQNUM=1096, IFINDEX=7, ACTION=add, INTERFACE=eth0}'.
                              02-09 11:54:59.455 D/Ethernet(258): Adding eth0
                              02-09 11:54:59.455 D/Ethernet(258): acquireWakeLock USB Ether
                              02-09 11:54:59.455 D/CommandListener(81): Setting iface cfg
                              02-09 11:54:59.455 D/CommandListener(81): Trying to bring up eth0
                              02-09 11:54:59.925 D/dalvikvm(403): GC_CONCURRENT freed 358K, 11% free 6646K/7431K, paused 12ms+2ms, total 31ms
                              02-09 11:55:01.245 D/dalvikvm(403): GC_CONCURRENT freed 429K, 11% free 6647K/7431K, paused 12ms+6ms, total 39ms
                              02-09 11:55:01.715 D/dalvikvm(258): WAIT_FOR_CONCURRENT_GC blocked 0ms
                              02-09 11:55:01.835 D/dalvikvm(258): GC_EXPLICIT freed 310K, 19% free 10716K/13127K, paused 2ms+13ms, total 126ms
                              02-09 11:55:02.155 D/dalvikvm(2681): GC_CONCURRENT freed 678K, 15% free 8414K/9799K, paused 8ms+7ms, total 59ms
                              02-09 11:55:02.315 D/MediaScanner(403):  prescan time: 64ms
                              02-09 11:55:02.315 D/MediaScanner(403):     scan time: 1360324375237ms
                              02-09 11:55:02.315 D/MediaScanner(403): postscan time: 2ms
                              02-09 11:55:02.315 D/MediaScanner(403):    total time: 1360324375303ms
                              02-09 11:55:02.335 D/MediaScannerService(403): done scanning volume external
                              02-09 11:55:06.255 D/dalvikvm(2681): GC_CONCURRENT freed 726K, 15% free 8393K/9799K, paused 11ms+3ms, total 58ms
                              02-09 11:55:07.545 D/dalvikvm(2681): GC_CONCURRENT freed 719K, 15% free 8386K/9799K, paused 17ms+3ms, total 65ms
                              02-09 11:55:11.655 D/dalvikvm(2681): GC_CONCURRENT freed 697K, 15% free 8387K/9799K, paused 12ms+3ms, total 44ms
                              02-09 11:55:13.075 D/dalvikvm(2681): GC_CONCURRENT freed 711K, 15% free 8402K/9799K, paused 14ms+7ms, total 73ms
                              02-09 11:55:14.025 D/dalvikvm(2681): GC_CONCURRENT freed 726K, 15% free 8387K/9799K, paused 13ms+4ms, total 57ms
                              02-09 11:55:15.235 D/dalvikvm(357): GC_CONCURRENT freed 1032K, 55% free 9314K/20295K, paused 14ms+4ms, total 60ms
                              02-09 11:55:15.455 D/Ethernet(258): Interface eth0 link up
                              02-09 11:55:15.465 D/EthernetService(258): getEthernetIfaceState()
                              02-09 11:55:15.465 D/EthernetService(258): flags=0x1003
                              02-09 11:55:15.465 D/EthernetService(258): state=up
                              02-09 11:55:15.465 D/EthernetService(258): getEthernetCarrierState()
                              02-09 11:55:15.465 D/EthernetService(258): carrier=1
                              02-09 11:55:15.465 D/Ethernet(258): checkUseStaticIp() : user set to use DHCP, about to Return.
                              02-09 11:55:16.625 D/dalvikvm(2681): GC_CONCURRENT freed 673K, 15% free 8425K/9799K, paused 14ms+4ms, total 65ms
                              02-09 11:55:17.455 D/Ethernet(258): Interface eth0 link down
                              02-09 11:55:17.465 D/dalvikvm(2681): GC_CONCURRENT freed 742K, 15% free 8408K/9799K, paused 4ms+4ms, total 56ms
                              02-09 11:55:17.655 D/CommandListener(81): Clearing all IP addresses on eth0
                              02-09 11:55:17.655 D/ConnectivityService(258): ConnectivityChange for ETHERNET: DISCONNECTED/DISCONNECTED
                              02-09 11:55:17.655 D/ConnectivityService(258): Attempting to switch to mobile
                              02-09 11:55:17.655 D/ConnectivityService(258): Attempting to switch to WIFI
                              02-09 11:55:17.655 D/ConnectivityService(258): Attempting to switch to PPPOE
                              02-09 11:55:17.665 E/Ethernet(258): DHCP request error:DHCP result was failed
                              02-09 11:55:17.935 D/dalvikvm(357): GC_CONCURRENT freed 1013K, 55% free 9324K/20295K, paused 13ms+4ms, total 56ms
                              02-09 11:55:18.535 D/dalvikvm(2681): GC_CONCURRENT freed 690K, 14% free 8447K/9799K, paused 20ms+5ms, total 76ms
                              02-09 11:55:19.545 D/dalvikvm(2681): GC_CONCURRENT freed 758K, 15% free 8410K/9799K, paused 13ms+5ms, total 56ms
                              02-09 11:55:20.665 D/Tethering(258): MasterInitialState.processMessage what=3
                              02-09 11:55:20.765 D/RKUpdateReceiver(420): action = android.net.conn.CONNECTIVITY_CHANGE
                              02-09 11:55:20.765 D/PicasaUploaderSyncManager(1394): active network: null
                              02-09 11:55:20.765 D/PicasaUploaderSyncManager(1394): background data: true
                              02-09 11:55:21.615 D/dalvikvm(2681): GC_CONCURRENT freed 689K, 15% free 8426K/9799K, paused 15ms+3ms, total 58ms
                              02-09 11:55:22.555 D/dalvikvm(2681): GC_CONCURRENT freed 735K, 15% free 8413K/9799K, paused 16ms+3ms, total 75ms
                              02-09 11:55:24.105 D/dalvikvm(357): GC_CONCURRENT freed 1045K, 55% free 9308K/20295K, paused 13ms+2ms, total 66ms
                              02-09 11:55:24.285 D/AudioHardwareALSA(87): Audio exiting sandby will open audio device
                              02-09 11:55:24.385 I/ALSAModule(87): open devices: 0x2
                              02-09 11:55:24.385 I/ALSAModule(87): Initialized ALSA PLAYBACK device AndroidPlayback_Speaker_normal
                              02-09 11:55:24.925 D/dalvikvm(2681): GC_CONCURRENT freed 673K, 14% free 8458K/9799K, paused 16ms+5ms, total 68ms
                              02-09 11:55:26.055 W/InputAttributes(434): Unexpected input class: inputType=0x000000b0 imeOptions=0x00000006
                              02-09 11:55:26.205 D/dalvikvm(434): GC_CONCURRENT freed 604K, 11% free 8442K/9415K, paused 13ms+6ms, total 71ms
                              02-09 11:55:26.425 D/dalvikvm(2681): GC_CONCURRENT freed 559K, 13% free 8606K/9799K, paused 12ms+19ms, total 78ms
                              02-09 11:55:27.635 D/dalvikvm(2681): GC_CONCURRENT freed 817K, 13% free 8589K/9799K, paused 15ms+2ms, total 74ms
