Bricked Nextbook 7 Premium SE
    I need help... please tell me what i should do... It can't boot now... what ROM should i install?
    Re: Bricked Nextbook 7 Premium SE
    Did you have backup your original rom..? Try to install it via rktool.. it should help you boot again..
    Sent from my PG06100 using Tapatalk 2
      Nope. I didnt make a backup. problm start when i root it.
        Only root then it bricked..? Try to enter the recovery by resetting the device, then push power and volume down button at the same time. If you see an android robot, then push power button and volume up at the same time. Then you can choose restore system from below menu.. hope this will help..
