UG802 - HELP, not noob !
    Hello all,
    I have a problem with UG802. If the device is plugged into a USB adapter in the "wall" so to 5 seconds after the restart and start all over again. When powering it via usb in the laptop and runs fine. Another adapter I tried with no result. My adapter has a USB 1A and the notebook should give a maximum of 0.5A. I tried to flash ROM but it did not help. Any ideas?
    EDIT: Now I connect with my charge adapter from phone with 0.7A and working fine... :-(
    It's simple! You need to buy an good quality dc USB power supply for your ug802. 2000ma is necessary. I am using an Philip surge protector and an iPad power supply, both of which work fine. Click image for larger version
