Warning***
This is for the Nextbook 7 premium ONLY!
Known working on Nextbook 7 premium tablets with serial numbers starting:YF1011
DocHoppy Presents!
DocHoppyRom Full On Root v2.0
and
DocHoppy Cramfs Style 3.0
Based off the official update image released by nextbook.
Major thanks to FINLESS BOB!!! GREAT HELPFUL GUY!
PRESENTING DOC HOPPY ROM
CRAMFS STYLE 3.0
AND
FULL ON ROOT v2.0
Disclaimer: I am not responsible for Bricked Tablets. This is known to work on tablet with SN starting with YF1011, and some YF1211.
First you will need to decide which version of the Rom you are going to load. The CRAMFS Style version has SU but you CANNOT write to the /system directory. This is a good all around Rom for those who may need SU but do not need to write to /system.
Full On Root is just that, you have full read write to the /system and can customize the Rom to your hreats content.
HOW TO INSTALL:
TO FLASH CRAMFS STYLE 3.0 Put the UPDATE.IMG file from the Cramfstyle Folder onto your SD card, while tablet is on and follow the on screen instructions.
After running the self extracting Zip file you will have a directory containing the following folders and files.
Drivers (folder)
CramfsStyle(folder)
FullonRoot(folder)
Log(folder)
Language(folder)
Readmefirst.txt
Rkusb.log
RkusbComm.dll
Setting.ini
RK29update.exe
To flash Full On ROOT, Plug your nextbook into your PC via usb cable. Turn your nextbook over and with a safety pin or something of similar size, press and hold the reset button for 2 to 3 seconds.
Run the RK29update.exe
Select your Rom files via the boxes containing the .... And navigate to the correct directory for the rom you want to install.
Insert eache file in order according to the update tool.
Clear IDB. (this is like a lowlevel format for the Rom tool:
After the Tool says OK. Select Run. This will begin to load the Rom onto your tablet. It will go through loading and then checking the Rom install.
After the Rom loads and the tool comes back with an OK, patiently wait for the tablet to reboot, and load the new ROM. If the tablet is still connected to the pc via USB when the rom boots it will show the screen allowing you to select weather or not to turn on USB storage. Press the home key and you will be given a choice of Golauncher or Rklauncher. (go lock is a screen lock program.)
Enjoy the Rom!
Features for both Roms:
Complete and correctly working market. It now correctly associates the tablet to your gmail account allowing purchases from market.
Launcher 3.0 as well as Go launcher ex. Launcher 3.0 was pulled from an rk2918 firmware3.0 update and put into this rom.
Google Calendar is now back and working correctly.
Original Email is back and working correctly.
Included Kindle App
Included Estrongs file explorer.
Both have SU though the Cramfs version cannot write to SW.
Removed Apps Added in last release and return to more of a original rom state.
Rom is pretty clean. And seems speedy.
Cramfs Style 3.0 Rom has 200mb internal Ram +/-
Full On Root 2.0 has 894MB of Free Internal Ram.
Cheers!
DocHoppy
Keep in mind this is the first version of this ROM. There will be updates and changes made.
FUTURE CHANGES:
Custom Theme Changes.
More Tweaks to the system.
Long Term Wants:
Power Menu change to include recovery boot.
Power Menu change to include restart.
This is a work in progress.
Linked here for image.
Non Add Showing Link.
DocHoppyFullOnRoot2.0
New Cramfs style Rom is still Available Here.
DocHoppyCramfsstyle3.0
To install DocHoppyRomv3.0, rename .img file to update.img, download update.img file, copy to SD card, and follow the prompt.
Enjoy.
Disclaimer:
Not responsible for bricked tablets.
Enjoy!
Also visit www.freaktab.com
