The new Ployer MOMO19 is an Allwinner A31 powered slate with a below average 9.7 inch IPS screen. Yes, this device is all about the chipset, and I’m talking about a quad-core processor based on Cortex-A7 frame. And until the RK3188 powered PIPO M9 goes on sale at the end of this month, this is probably the most powerful Chinese tablet you can get your hands on.
Key Features
◇9.7” 16M-color IPS display of XGA resolution (1024X768 pixels)
◇Weighs 630g, 238.4mm*185.5mm*9.3mm in size.
◇Allwinner A31 chipset: Quad-core 1.2GHZ ARM Cortex-A7 processor; 2GB of DDR3 RAM; PowerVR SGX544MP2 GPU
◇Stock Android 4.1 Jelly Bean
◇16GB of built-in-memory
◇VGA front facing camera; 5.0MP rear-facing camera
◇ACC Stereo speaker
◇HDMI TV-out
◇USB host
◇MicroSD card slot
◇Standard 3.5mm audio jack
◇Adobe Flash 11 support
◇2160p video playback
◇8000mAh Li-Po rechargeable battery
The tablet is packed in an extremely slim paperback box.
Along with the tablet itself, I also found those things in the paperback box.
Design
My first and lasting impression of the MOMO19 was one of a well-constructed and durable machine. The tablet's brilliant In-Plane Switching (IPS) screen is a premium panel that's fronted by damage-resistant Glass, and the back side is black aluminum. These two sides of the slate give it a look and feel that instills confidence when you hold it in your hand.
At 630g and 9.3mm thick, it's not the lightest or thinnest option around, though ployer isn't exactly known for churning out ultra-slim tablets. Still, the MOMO19 feels great in hands, and that extra bit of thickness lends the device a solid, reassuring grip.
Similar to other Chinese Android tablets, I have seen a strong showing of ports and slots. Besides the Micro USB data port and 3.5mm audio jack, there is also a Mini-HDMI connector, a 2.5mm charging connector, and a microSD card slot to augment the 16GB of internal storage. What should be mentioned is that Ployer has carefully covered the micro SD card slot and HDMI, USB port with the dust-proof lid. As for hardware controls, there are only a power/standby switch and a back button. You have to use the touch screen to control the volume of the device.
As for the 9.7 inch display itself, it can hardly be described as eye-catching. The resolution stays XGA standard with a PPI of 132, easily dwarfed by those tablets with Retina or FHD displays. However, I would still say it’s a decent choice since the Soc. manufacturers haven’t made that much progress in the GPU department of the chipset to work a retina display perfectly.
The IPS display on the MOMO19 has great viewing angles and vibrant colors, but the brightness of the screen is quite weak, making it almost impossible to use the device outdoor.
Despite having only one speaker gate, this model played music clearly. We tested it with Fun’s energetic "We are Young" and Lana Del Rey's soft and melodic "Video Games", not only was the music comprehensible, the volume was also quite pleasant. The ACC enhancement gives the sound some stereo effect, too. I have already streamed many clips of online videos since I received the tablet two weeks ago.
I've rehashed Jelly Bean so many times that it feels downright superfluous to spend more than a few sentences outlining this tablet's Android 4.1.1 software. Still, with Google I/O around the corner, the prospect of Jelly Bean looms, and it's worth mentioning that newer devices such as the MOMO19 will probably get a 4.2 update at some point.
As with many other Chinese Android tablets, the volume rocker sits on the system bar. Ployer didn't exercise more restraint than usual with the software pre-load on this tablet. Booting the tablet up for the first time, you'll be greeted with Dopool, Chinese perpetual calendar, YouTube, QQ music, Winrar, Baidu Input and 4k video player app-- not to mention the full Google suite of apps and a bundle of productivity programs including MOMO HD app market and Documents to go -- in the app menu. Never fear, though: you can cut down on the bloat by disabling what you don't need under Settings.
Navigating the Android 4.1 interface is very fluid and easy, I have never encountered any glitches with the tablet's responsiveness. Even when I was scrolling through photo-heavy sites, the MOMO19 stayed smooth and sloppy.
