Yuandao N101 RileyROM 1.9
    Now there are choices.
    This is the RileyROM 1.9 ROM for the Yuandao N101-1. It won't work on the N101-2. It is based on the most recent Yuandao firmware. If you are using my original release, It is pretty much the same as 1.9b, but since I have been learning ROM development, I have cleaned things up a little bit and polished the branding image on the boot screen...that's it.
    1.9a is rooted, with 2gb of user app space, CWM Recovery, Init.d support with the stock UI. Here is the link:
    1.9b is the Snakegenmod version with some cool UI tweaks:
    Both kits include the 135 and the 123 kernels to use as you like. I prefer the 135 on my tablet, but others have experienced some touch screen problems with it and elect to use the 123 kernel instead.
    Please post any feedback for this ROM here:
    Feedback
    If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
    Last edited by rrileypm; 08 May 2013, 01:49. Reason: Update for versions "a" and "b"
    Randy
    Originally Posted by rrileypm
    There is the link to the latest ROM for the Yuandao N101:
    Since the FTP server is giving me problems, here is an alternative link:
    https://docs.google.com/file/d/0Byxb...it?usp=sharing
    Thanks your post
