V6SuperCharger speed script install requires ADB device drivers for Windows 7
    I'm trying to get V6Supercharger installed on my iMito MX1, and so far i can only get it 50% supercharged. The last 50% requires ADB "Android Debugging" drivers for Windows so I can patch and install the "services.jar" file. Does anyone know if there are ADB drivers for the MX1 or any of the Mini PCs out there? I can't detect the Device ID.
    Also, has anyone with a Mini PC and a Finless ROM been able to get V6SuperCharger at 100%? If so how did you patch the "services.jar" file?
    Thanks,
    megeeks
    If you are using a rooted ROM then you do not need ADB.
    Just use ES File explorer and enable root explorer and mount system a RW in ES FIle explorer.
    Using ES File explorer prop the existing services.jar and look at the permissions.
    Now rename the existing services.jar to services.old
    Now just copy the services.jar from SDcard into /system/framework
    Then set the permissions to the same as the original services.jar.
    Reboot and your done.
      Wich guide/site are you using? I can't get 100% and all scripts looks different!
      I tried to pach my service.jar by upload and patch it on website, but still 50% :-(
        I used this website for basic directions
        go down to "Hacking services.jar" section:
        The second step is what gets me. it's about patching services.jar through one of the options A-E. The last option 2E) WebApp won't work with Jellybean. The WebApp is not up to date. So I've been trying to patch through option 2A) and using "Ultimate Jar Patcher Tool". Directions here for option 2A) is at this site.
        After running the exe file for windows, the script stops loading and cannot find the device ID asking to try finding the correct windows drivers. I assume these are ADB drivers. That's where Finless said we do not need ADB for rooted devices. Part of the requirements for the computer Says you need java script and device drivers so that ADB works. I'll have to get back to Finless about that one.
        if you have any luck patching the services.jar file let me know! I would love to get this speed script running at 100%.
          After I check permissions and rename the existing services.jar file to services.old, where do I get the new "services.jar from SDcard" file? Is it patched yet? I still will need help patching this file.
          Then as stated above,I can copy over the file into /framework and copy the permissions from the original services file to the new one.
