How to remap our inputs devices in our tv sticks.
    I used tincore keymapper to map an Xbox controller for survival craft. I've never played shadow gun so I can't say for sure how well it will work, but it's a free app so it's worth a shot.
      Re: How to remap our inputs devices in our tv sticks.
      Originally posted by leolas View Post
      Uff, remap joystick using this way can be difficult, I think that some apk make it in an easy way.
      Is an analogic joystick? Or a pad controller?
      leolas.
      @ Leolas: the controller is an digital/analogic joystick but i found how to map the analog sticks. it was not easy but it can be done.
      i edited the axes of the joystick on .kl file with the vendor and product number of my joystick.
      the axes were messed pretty bad because my joystick has only four but in the generic.kl there are a lot more, so i had to go by exclusion.
      i just putted a # in the front of the line for the axes and then i tested it in the game (shadowgun).
      if the stick stoped moving then i new that line was for a specific axe, if not i went on and marked the other lines with #.
      and for the keys i used the keytest app and found which were the keys for my joystick.
      so in the end i made it and now i have a backup of that file too, in case i want to flash another firmware to the device.
      @ Crithon: I use Tincore app too for some games like Real Racing that dont support the joystick function, but for shadowgun i thought it was better to play it without a middle app for the controller
      Cheers
      Sent from my GT-I9300 using Tapatalk
      FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
      https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
      My Plexi MK802IV mod
      http://www.freaktab.com/showthread.p...xi-MK802IV-mod
        Cheers
        Good work!! If you can, please upload your kl file, it will be useful for other people too
        leolas.
        My devices:
        Gearbest.com)
          leolas.
          Hi Leolas, i uploaded the kl file to google drive.
          Here is the link: https://docs.google.com/file/d/0B5GX...p=docslist_api
          Guys remember to change the file name according to your controller and the file permissions.
          Hope it helps
            Hope it helps
            Sure that it will help some people. Thanks!!
            leolas.
            My devices:
            Gearbest.com)
              Hi, Thanks for the guide its really helpful. I have a Rii Mini keyboard (this:http://www.landmarkpc.co.za/store/images/ZW-51009.jpg) but for some reason the e button takes me home instead of the home button. I tried this but keytest said keycode unknown. How can I fix this? Thanks.
              Also is there a way I can make the e button take a screenshot?
                Just like mine, well mine is white
                And this is the only button that can't be remaped by me. I learned to live with it.
                leolas.
                My devices:
                Gearbest.com)
                  leolas.
                  Using another app (KeynumberTracker) I was able to find out that it is key number 144 (for the home button the e button is 172).
                  This is great so now we both have a problem solved. The key is commented out in the kl file.
                  Maybe if we comment out everything then we can find the other keys and have proper support for this on our dongles.
                  By the way, is there a way to map a button to screenshot?
                  Thanks again for the guide.
                    leolas.
                    Please see my last post if you haven't
                      I dont know if a button can be maped to screenshot, because this is not an standard function
                      leolas.
                      My devices:
                      Gearbest.com)
                        Is there anyway to do the same thing for gaming mouse. Like assign the buttons to vol up down and home screen?
                        Sent from my GT-N7100 using Tapatalk
                          I have a MiniX A2 mouse and I'm trying to remap some of the buttons so they work with my MK908II. I tried it with 2 keys first to see if I got it right and I haven't.
                          Mapped:
                          key 122 HOME
                          key 132 MENU
                          I used the keytest.apk to find out which keys to change. I've checked I've got the right Vendor and product. permissions are set right. When I press the 'home' button on the remote in the browser it moves the page to the top. So maybe 'Home' isn't the correct command as I want it to return to the desktop/launcher. I'd also like to map a key to the app switcher/multitasking as well but I'm unsure what the command is for this?
                            yes it can be done
                            Mapped:
                            key 122 HOME
                            key 132 MENU
                            Look at the minix rom definition for the A2, there must be the codes used.
                            leolas
                            My devices:
                            Gearbest.com)
                              yes it can be done
                              leolas
                              Ah it's the 'scancode' that's needed from the keytest.apk not the 'keycode' number. I was to remap the home, menu and app switcher buttons. I'll post the codes tomorrow for any fellow MiniX A2 remote users.
                              Sent from my Desire S using Tapatalk
                                These scancodes are for the MiniX NEO A2 remote:
                                Home button 102
                                Menu button 60
                                Multitasking button 240
                                Volume up 115
                                Volume down 114
                                Vendor ID is 0c40 (zero's - not the letter o)
                                Product ID is 7a18
                                So the filename should read "Vendor_0c40_Product_7a18.kl" (without the quotes).
                                I've only remapped the above buttons so far, using the volume buttons as zoom. in the file they read:
                                key 102 HOME
                                key 60 MENU
                                key 240 APP_SWITCH
                                key 115 ZOOM_IN
                                key 114 ZOOM_OUT
                                The APP_SWITCH doesn't bring up the proper multitasking menu, just an app switcher for recent apps. I'd prefer it to bring up the multitasking menu though so if anyone knows how to do that?
