Safely Removing USB Mass Storage Device With Android 4.1
Every JB rom I have seen to date is missing the ability to unmount USB storage devices. I am not sure why!
It's very annoying.
afaik, the reason why in Windows there is that option is because the system uses write caching when transferring files (on NTFS partitions anyway), so the window saying "file is being transferred" is closed before the device has actually finished writing.
As long as Android does not use write caching (kind of stupid if you have less than 1 GB of actual RAM) there shouldn't be any issue in yanking off usb stuff as long as you are sure that no app is working on it.
I highly doubt a sudden power loss on the memory device does damage it, as for either flash drives and HDDs there is no command to "shut down" their hardware.
Originally posted by bobafetthotmail View Postafaik, the reason why in Windows there is that option is because the system uses write caching when transferring files (on NTFS partitions anyway), so the window saying "file is being transferred" is closed before the device has actually finished writing.
Android has similar functionality however it is only tailored to microSD cards. Might be wrong on this one. Have a chance to check it out with a Galaxy Note 10.1 running Android 4.1 (official update).
Originally posted by digiPixel View PostWhat will really result in data loss on the storage device is when an app or some other piece of software is using the device when it is unplugged. That is why the Eject option is available on all of the major desktop OS's (Linux, Windows, Mac OS). To make sure that the device is no longer in use, and if it is display a warning message otherwise display a message saying the device can be safely removed.
As long as you disconnect the device when led isn't indicating "writing", no data loss happens.
Originally posted by EdTToday people talk like 1GB of RAM is like nothing, just a couple of years ago 1GB was a lot and still is if you know how to use it !
I personally think Android's sweet spot for heavy use is around 2-3 GB, with that you can pre-load more or less everything at boot with still a gig to spare, and that would give the device a lot of responsiveness.
Anyway I was talking of write caching. Devices with 1 GB or less rarely have write caches big enough to matter (otherwise they would impair the system as that is ram eaten up straight to contain the transferred files), so it makes sense to drop the feature entirely.
There are currently 2696 users online. 1 members and 2695 guests.
