A new 1.4 ROM coming
"Forgive them as they know not what they do"Tags: None
No sorry I have not tried that yet! Not enough time in my day to test everything
I will look into it though but maybe not in 1.4.
Since you are rooted you know you can make this change yourself for now. I like to test things 100% before I cook them in a ROM.
Originally posted by Finless View PostNo sorry I have not tried that yet! Not enough time in my day to test everything
Any chance of adding init.d in 1.4 version?
Probably just add in init.rc:
# Execute files in /etc/init.d before booting
service sysinit /system/bin/logwrapper /system/xbin/busybox run-parts /system/etc/init.d
disabled
oneshot
set_perm_recursive 0 2000 0755 0750 SYSTEM:etc/init.d
set_perm 0 0 0755 SYSTEM:etc/init.d
I can't test this becouse I can't write in init.rc
I don't like to add things to a ROM I cannot test. So if I add this it will be a test ROM for you to test. I can do this now for 1.3 first for you to test.
Where in the init.rc should these go? Please give me the line that exists there ahead of wheree you want this inserted.
Originally posted by Finless View PostI don't like to add things to a ROM I cannot test. So if I add this it will be a test ROM for you to test. I can do this now for 1.3 first for you to test.
disabled
oneshot
Do you have a linux system setup? If so I can tell you how to unpack and repack boot.img and you can easily test this stuff. For boot.img you do not have to make an entire ROM and you can make changes and get by with flashing only boot.img.
You sound like you know what your doing so you might help us continue to improve these ROMs?
Originally posted by Finless View PostDo you have a linux system setup? If so I can tell you how to unpack and repack boot.img and you can easily test this stuff. For boot.img you do not have to make an entire ROM and you can make changes and get by with flashing only boot.img.
OK first things first. You need to go get RK Utilities and get them compiled in cygwin.
You will need rkcrc to be compiled. This version of rkcrc from the distro above has the -k option. The old version only had the -p option which wont work.
Personally I use VirtualBox which is free and I installed Ubuntu in a Virtual Machine. Much better than cygwin. If your going to get serious about modding ROMs you will hit limits that cygwin cant do.
Originally posted by Finless View PostOK first things first. You need to go get RK Utilities and get them compiled in cygwin.
Unpack, change file, pack, boots - everything ok
Problem in my previous test was rkcrc -p now with -k work great - thank you
Unfortunetly init.d not work, I must read more about this.
BTW, I made new thread with your ROM on polish forum: http://forum.android.com.pl/f476/cus...v1-3-a-143097/
Thanks for making the post on the Polish forum. I went and checked it out using google translate. Good job! Glad I could help for this tablet. Wait till you try 1.4 my friend! Your gonna love it.
OK so fill me in, what does this command do? If I understood it I might be able to tell you where it needs to be. I am still not an Android OS expert by any means!
Originally posted by Finless View PostOK so fill me in, what does this command do? If I understood it I might be able to tell you where it needs to be. I am still not an Android OS expert by any means!
If this start work we can try lot scripts-tweaks.
There are currently 1867 users online. 0 members and 1867 guests.
