FLASH MODE FAILED
    FLASH MODE FAILED
    I downlaoded some ROM's to Flash and get root on my Mk802 (I mean it is) A9 Dual Core + 4 GPU.
    If I try to Reboot to Flash mode always the msg FLASH MODE FAILED comes and I go wen to step 7 nad disconnect -> usb mtb -> usm storage and what else.
    But nothing happend only "FLASH MODE FAILED"
    greets
    i experienced some of the same issue while installing on my mk809.
    what worked for me, what going into android setting on the tv stick, into the advanced settings (found on the top right corner from "storage" setting under device", and change it to "USB Mass Storage" from "USB Media".
    If it is already on USB Mass Storage, then click the USB Media and go back to USB Mass Storage.
    If this doesn't work, try clicking the "Connect to PC" on/off, and keep trying till it works.
    I had to do this 3-4 times before it worked, but finally it worked.
    Good luck with that
    Bang
      Thx 4 answer I'll tr it again
        It works!
        Thx it works now, after RAGE mtb-storage-mt-storage-mtb-storage ...... serveral times later despret pushing the last time the button and mirage it works ^^
        Thank you 4 ur help lets do....
          That's what happened for me too after several attempts :-).
          Glad it worked out!
