Whatsapp on imito MX2
    Hi All,
    Just recieved my imito MX2 and already installed Finless Rom 1.5 which is running smooth.
    I am trying to install whatsapp om my MX2 but when I start the application it says that whatsapp is not supported on tablets. Already searched the internet but the only solution I came across is using a rooted androidphone and backup/restore the app to the MX2.
    Anyone treid this on MX1/MX2?
    I don't have an andoid phone so other solutions are welcome.
    Regards,
    Alex
    Me too tried to install it on MK808b with finless rom 1.6a and it didn't work, and I wish bob would answer this question.
      Try my 1.7 rom. I bet it works.
        alex, finally, I was able to make, as you said when you try to download it from Google play you would have the compatibly problem, but try to search for whatsapp apk online and the first link was from whatsapp.com, I clicked on that link and downloaded the app, then run it with no problem, try it, it will work.
          will this work on a non rooted device?
          can you actually use the messaging services over wifi?
            Works
            Hi Bob and Mishtag,
            Yep can confirm it works now
            Thanks,
            Alex
              wakkaday, I am not sure about non rooted device, but with my MK808b with finless Rom 1.6a, I am able to send and receive messages, pictures and clips, however, why don't you try it and let us know, just follow my instructions.
                Try this FMWhatsApp. This is a modified version of WhatsApp and it also works on non-rooted android devices.
                • gefattern
                  gefattern commented
                  Editing a comment
                  Hi ,
                  you answered on a 7 years old , question , but , welcome on FREAKTAB ,
                  greetings / gefattern
                Thanks for saying welcome on freaktab and I'm sorry for that
