4oD app
    4oD app
    Anybody got this working on the Minix X5?
    Installs fine but then will not load any content as it requires a wireless or 3g connection, my Minix X5 has an ethernet connection.
    I have tried enabling wireless hotspot to try and fool it but i still receive the "no internet detected please connect via wireless or 3g" error.
    anybody got any ideas as the app is a lot easier and cleaner than the browser based solution, it looks and works great on my Samsung Tab 2 10.1
    Cheers
    Sharpcroft
    Re: 4oD app
    Hi
    I have the same issue with the X5 connected via Ethernet. However when I disconnect Ethernet and connect via wifi 4od is happy BUT it doesn't allow playback on a TV!
    How dumb is that! It does the same on my mhl compatible phone when I connect it to my TV via hdmi.
      from what i have read,
      some apps are made just for phones and tablets,
      which have only wifi,
      not ethernet option,
      so it will give the error message if not wifi setup,
      i have had to switch my settings a couple times for things like that,
        Ethernet issue aside it is a real pain that it won't work as it thinks it is connected to a TV (I'm using it with a 24" touchscreen as a big tablet and it still says it) I guess it might use something like the screen resolution to determine it.
        I wish all the TV apps would get it sorted - iPlayer just opens a web browser!
