The Benyi Miracle One (AKA Dolphin) has the hardware needed for high end Android tablets. But still, with so many more tablets currently on the market, choosing the right one involves a great amount of research deliberation, so let’s take a look at what this package from Benyi has to offer.
1.4 GHz Exynos4412 Quad-Core Processor
9.7” 1024×768 IPS display
1GB LPDDR2 RAM
12,000 mAh Lithium battery. (Approximately 10 hours of use)
5MP rear camera
3MP front camera (webcam)
Stereo Speakers
Specs:
Operating System: Android 4.0.3
Model: Benyi Miracle One (Dolphin)
Display Technology: IPS capacitive touch screen
Screen Size:9.7 inch
Resolution:1024*768
CPU Manufacturer: Samsung
CPU Model: Exynos 4412 (Quad core Cortex-A9)
CPU Speed: 1.4GHz
GPU: Quad core of Mali-400MP
GPU Speed: 400MHZ-440MHZ
RAM: 1GB LPDDR2
Hard Drive Capacity: 16GB
Storage Card Support: No
Camera: 3MP+5MP Auto Focus
HDMI: No
Bluetooth: No
GPS: NO
G-Sensor: Yes
Gyroscope: Yes
Audio: Built in stereo speakers / Built in Microphone
Language: Multi-language support
Battery Type: Li-ion, 12,000mAh
Charging Voltage: 5V - 2A
Color: White plus sky blue
Item Dimensions/ W*D*H:238.5×181×11mm
Net Weight: 680g
Connectors
Ports: 1 x Micro USB port (with OTG support)
1 x Audio jack
Communications
Wireless Connection: WIFI 802.11 b/g/n
The Benyi Miracle One, along with a USB data cable, an OTG cable as well as a pair of earphones is held by a very interesting, yet very expensive-looking see-through plastic packing box, which kind of reminds me of the Apple iPod touch, only it comes gigantic.
The battery charger is packed in a smaller paper back box.
Besides, I have also received a white leather case which is a perfect fit for the tablet and piece of anti-friction screen protection cover. All of the standard fittings of the Benyi Miracle One are of relatively high quality.
The Benyi Miracle One has a stunning iPad-alike design, as this tablet features a 9.7 inch screen up front, pure white bezel and almost the same size as iPad2. The only difference you would notice is probably the blue sidelines around the bezel, and the absence of the famous home key.
Above the display, a 3.0 mega-pixels front facing camera sits in the right corner ready for our video chatting needs of self-portrait.
Flipping over to its backside, you will find more differences from the iPad2. The surface of the Dolphin’s backside is ABS engineering plastic, which feels very smooth, while the iPad2’s backside surface is made of magnalium alloy, which gives the device more of a frosted feeling. The Dolphin is also treated to a respectable 5.0 mega-pixels auto-focus camera, which can shoot relatively sharp images to share on Twitter and Facebook. The triple speaker gates can be found at the lower left, right near the bottom edge, this could prevent sound blocking while you put the tablet on a flat surface. You could also find Benyi’s Logo and some other information about the device on the lower middle of the tablet’s backside.
Just like the iPad2 and some Samsung tablets, Benyi has taken the minimalist approach, opting for just power/standby, screen rotation lock and volume buttons as the only physical controls and Micro USB port and 3.5mm audio jack as the only connectors on the device which means, somewhat disappointingly, that there’s no sign of HDMI or SD card ports.
At 680g, it’s over 200g heavier than the Samsung Galaxy Tab8.9, and measures in at 11mm in thickness which as a result, makes it extremely uncomfortable to hold in one hand. Benyi has claimed that the extra thickness is for the 12,000 mAh battery, so how can I not forgive them for not making the device a little slimmer?
Whether you find the design of the Miracle One good-looking is more of a personal taste. For me, I would say I probably prefer tablets like the PIPO M8 or the Motorola XOOM which represent the essence of black technology. But I do adore the overall clean appearance of the Miracle One. As it is manufactured by a famous OEM (FOXCONN), its build quality can also be guaranteed.
We’ve seen plenty of Chinese tablets utilizing IPS displays of some sort, like the Ainol Hero and the PIPO M8. As a higher-end device, the Miracle One hasn’t gone beyond any of them by featuring a normal 9.7 inch 1024*768 pixels IPS display. This is still a decent choice since no android tablet with an FHD or retina display works fine enough to kick XGA screens out of the scene.
However, I would not suggest you to expect its quality to be as good as the Super IPS+ displays featured on those market-leading tablets such as ASUS Transformer Prime. Even though it has great viewing angles and color saturations like all IPS screens do, its brightness is not strong enough to support outdoor use.
The brightness of the Miracle One’s Display is not as good as the One featured by PIPO M8
