How to secure my MK808B Android mini pc from unauthorized access?
    Hi all, I'm hoping you can help me with this concern. Short of keeping my MK808B (genuine; running Finless 1.6a) physically locked up when I'm not using it - how can I secure it? For example with something like a lock screen.
    I can't find the lock screen settings in Finless ... And they didn't even work in the stock ROM.
    My only other option is to apply and then delete my Google account off the device whenever I need it.
    Thanks in advance,
    ___________________________
    MK808B (Genuine) w/Finless 1.7
    Bump
    Any ideas ... anybody?
      The lock screen (using a PIN) on 1.7??
        Hi Old Man, thanks for the response. I didn't install 1.7 because the thread says it's in beta ... but I read through and now I'm tempted to try it out. Can you confirm the lock screen exists in 1.7?
          Sure can.
            I use an app called applock on my tablet, I just have it set to lock google play but you can set it to lock what ever apps you want.
            This way it doesn't bug you all the time but does stop others installing or buying anything
              Thanks, went to google play and set it to install when I startup the stick tonight
