USB dead after opening case...
    So, I opened my case to see if I had a clone or original like the video showed me, ever so gingerly and when I put the case back together my USB port will not work The external H/D lights up but will not read or even show up. I have since upgraded to the Finless 1.7 ROM and it still doesn't show up. I've tried 3 different H/Ds and a 8gb pen drive with no luck and have also tried 3 different USB cables with no luck. The port worked fine before opening the case.
    How do you think this happened? I didn't cut any wires or pull anything out of place.
    I tried hooking my H/D to the other port and it worked fine but that is also the port I use for my wireless mouse receiver.
    Tried 4 different USB apps also with no luck.
    Any help will be appreciated
    Thanks.
    Pop open the case again and take a close look at the contacts between the USB connector and the circuit board. You may have to carefully re-solder a broken contact.
    ___________________________
    MK808B (Genuine) w/Finless 1.7
      Whoops.
      Thanks.
      After opening the case again I did notice I might of scraped some metal off while using my knife to get the case open I ended up removing and re-soldering the USB and contacts and all is well again
        Re: USB dead after opening case...
        i will be opening mine soon to fix the antenna and i am worried about cracking the case or something. any video of how to do this safely?
        edit: someone recently made a video:
