serial # starting yf0911.
Download the image file.
Rename to update.img
Put the update.img file onto your SD card or internal ram for your nextbook.
If your next book is on, you will be prompted to run the new flash.
THIS IS ONLY A TEST. I DO NOT HAVE THAT SN# Nextbook,!!!
I want to be very clear, if you attempt to flash this on any other nextbook, you may be bricked untill you flash the orignal update.
Please test and let me know what you find.
Image Link below
TEST ROM IMAGE FOR SN#YF0911
Cheers!
