Crystal JBX 1.0
Features:
-based on stock JB ROM 1119 for Ainol Novo Crystal batch 2
-rooted
-init.d support
-stripped a bit, not much possible because of the relations between the apps
-standard stock cpu clock is 1.2Ghz, you can overclock to 1.512 with nofrills, but the crystal is a hot guy,
-supercharged services.jar, thanks to zeppelinrox
- added some apps I like
- moage launcher, based on adw launcher, thanks to moage
-hackers keyboard as option
special thanks to tattman65 for the awesome artwork in my ROM
notes:
If you are not shure how to use, read first this guide
Flash with stock recovery or more comfortable with TWRP 2.4.1.0 recovery
Please flash the ROM, if you have a batch 2 crystal tablet. I have not tested my ROM with the other hardware versions, so I can't assume what side effect you will have.
For batch 1 and 3 crystal hardware you can try the compatibility Patches: Batch 1 Batch3 from fuser-invent
credits: fuser-invent, Christian Troy and Soulflier for all the basic work
Now lets see, how this ROM work. Please report me issues, I will try to fix it.
JDfense
...and a song for the installation
