I have been trying to install the new libstagefright.so from Rockchip without any success on my MK802III.
Each time I install it, XBMC and the internet browser fail to open, they try to load for a couple of seconds then just crash back to the launcher home screen. Also if I reboot the device it gets stuck on the boot screen.
Has anybody else tried the new libstagefright on either the MK802III or the UG802 yet?
Have you managed to install it without any problems?
I use ES file manager with root set to copy (system set to R/W) the new libstagefright.so into the system/lib folder overwriting the old one
Then make sure the permissions are set to rw- r-- r-- on the new libstagefright.
So far I have tried the new libstagefright.so without success on:
finless 1.6 for Mk802III/ UG802
finless/2dark4u 1.7 for MK802III/UG802
and also UG802 High performace Rom from allminipc (2dark4u)
Am I doing something wrong?
