Help with eHome Media
I can not get any files to show using eHome Media Center. When I open the media player, Windows Media player shows but I get a media request list failure. XBMC will also show if I open it but 0 files are found. I set my media folder on my PC to shared under properties and I tried to set libraries up in both windows media center and XBMC but with no luck. What do I have to do to get the files to show?Tags: None
Assuming Windows 7, open Network and Sharing Center from Control Panel. In the lower left corner click on Homegroup and check the sharing settings there. Make sure the "Stream my..." is checked and then click on on "Choose media streaming options..." and make sure the eHomeMediaCenter is allowed. Also, look at the streaming settings in Windows Media Player Library.
Originally posted by JerseyFresh609 View PostI can not get any files to show using eHome Media Center. When I open the media player, Windows Media player shows but I get a media request list failure. XBMC will also show if I open it but 0 files are found. I set my media folder on my PC to shared under properties and I tried to set libraries up in both windows media center and XBMC but with no luck. What do I have to do to get the files to show?Last edited by billbmsn; 03 March 2013, 13:15.
Originally posted by billbmsn View PostAssuming Windows 7, open Network and Sharing Center from Control Panel. In the lower left corner click on Homegroup and check the sharing settings there. Make sure the "Stream my..." is checked and then click on on "Choose media streaming options..." and make sure the eHomeMediaCenter is allowed. Also, look at the streaming settings in Windows Media Player Library.
Originally posted by JerseyFresh609 View PostNew issue: My media lists are being cut off. Ehome will say something like 80 videos total, but ewhen I go in to the folder it is only displaying A-H and nothing after. If I go to music it's being cut off halfway through the A's. What could be causing that?
Also, see if all files show up in Explorer on your Android box.
There are currently 1278 users online. 0 members and 1278 guests.
