android magic header not found at start of boot img
    Hello Altogether!
    First I have to say: Im totally new into things like Android and stuff like that...so please be gracious when I ask silly questions!
    Some weeks ago I bought a MK808-b and I was really impressed by this tiny little device. After flashing Bobs Rom to my device which was sadly not working for me I flashed back the rom of my **** seller. (update_mk808b_box_400j1)
    To understand how everything really works I thought that it would be good....to dive deeper into the substance! Therefore I start to learn more and more about Android, Roms and stuff like that...
    Now I try building my own ROM....just to learn how it works!
    Ok ok...for the first time I try to modify a Rom which is working on my device.
    Now I got a problem and I dont know how to manage this:
    I use cygwin and the kitchen. I installed the cygwin with the kitchen and everything seems to work fine.
    With the help of Terminal Emu and BusyBox I packed my system folder and saved it to my external sd card.
    Code:
    su
    busybox tar -c system/* >> sdcard/system.tar
    After that kitchen want to have the META-INF Folder and the bot.img. I tried a few things to get the boot.img out of this working rom. With the help of RK29xxImageTools_v2.1 I got it now.
    When I now want to set full root to the Rom.... the kitchen alway tells me:
    Code:
    [B]
    1) Warning! android magic header not found at start of boot img
    2) Error: zimage is empty!
    3) No Ramdisk found![/B]
    Im not really deep into this...so I dont know how to fix it!
    Any hints from the (real) professionals?
    Thanks in advance...
    Joschi
    Here's a few posts that may help
    http://www.freaktab.com/showthread.p...or-RK-ROM-Devs
    http://www.freaktab.com/showthread.p...dev-s-approach
    http://www.freaktab.com/showthread.p...cks-by-Finless
    900Supersport
    freaktab developer
      Thanks...
      thanks for you quick anwer and your hints! I promise.... I will closely read the links you posted!
      One question: Is it really true...that its unpossible customize Roms only with Windows!? Do I really need a Linux machine?
        I only use windows to test flash a new ROM. Others use windows quite a bit and run linux as a virtual machine. As android is basically a linux kernel then you are best embracing it. Ubuntu and Linux Mint seem to be the versions to go for, both will dual boot with windows or work in a virtual machine.
        900Supersport
        freaktab developer
          Time 4 Linux again!
          Ok...I see...
          It´s time to set up a VM!
