NX003 II is powered by Dual Core RK3066 1.6GHz CPU and quad core Mali-400 GPU.It supports 3D acceleration,external USB flash drive,HDD,HDMI&AV output,DLNA and OTG connection.The biggest shining point of NX003 II is its built-in camera and mic,totally identical as Measy U2C.With the camera,you can easily experience the face-to-face talk in front of big screen.However,you need know it clearly:a good dock is badly needed for the device,or you can only see the surface of your desk or the ceiling of your room.
Hands-On Video:
Features:
- Brand new NX003II Dual Core Mini PC Android 4.1 RK3066 1.6GHz Camera DLNA AV/HDMI Output
- Built-In Camera&Mic
- Google Android 4.1.1 Jelly Bean OS, thousands of apps in Play Store
- Rockchip RK3066 cortex a9 dual core 1.6GHz CPU, Mali400 GPU, support 3D acceleration
- Big 1GB DDR3 Ram, support external USB flash drive and HDD
- Built-in USB2.0 port, you can use Air Mouse and many other USB devices with it
- Support both HDMI & AV output
- Support DLNA, you can share photos, music and videos between your phone and this TV box
- Multi-Language support
