Arnova 10b G2 Capacitive Screen - Custom ROM by Finless V1.4
"Forgive them as they know not what they do"Tags: None
- Stuck
Hi Finless,
Just show your message and was willing to give your Rom a try but my Arnova is completely blocked. Screen stay black (tried a lt of possibilities). It looks light I have no battery though it was connected the whole day to the charger.
I just hope I won't have to bring it back
As soon as I can I will try your rom.
Imkal
OK you should always be able to unbrick these tablets. Also while in bricked mode the charge light will not light!!!! Make sure you have power plugged in. Do not worry if light is on or not. Follow the instructions to put it in FLASH mode (recovery) it still should go into recovery even if battery is dead but plugged in to power.
Originally posted by Finless View PostOK you should always be able to unbrick these tablets. Also while in bricked mode the charge light will not light!!!! Make sure you have power plugged in. Do not worry if light is on or not. Follow the instructions to put it in FLASH mode (recovery) it still should go into recovery even if battery is dead but plugged in to power.
The tablet does not react to attempt at resetting or entering the flash mode! I'm fearing the worse! To make sure, your recovery mode is well the pushing on the Volume + and holding the rest 5'? If it is then I tried it to no avail!
It stayed charging and connected as USB the whole day and now, black screen!
Imkal
If you plug it in the PC and wait a bit and unplug does you PC make any bong sound showing something was plugged in and out?
When you plug it into your PC and go into device manager do you see anything listed? Like unknown device, rk29 device, anything?
Great Firmware - Small Problems
Just upgraded to the 1.4v Capacitive Screen. Love the speed, full Market, etc. but I have a couple of small problems that I was wondering if there is an easy fix to. The screen brightness control works backwards, dragging to the right (more highlighted bar) produces dimmer display. I when changing/holding the tablet in Portrait mode it is almost always upside down. Flipping it 180 still leaves it reversed to what it should be. Landscape mode for most apps seems to be OK. Thanks for all your hard work!!
Known problems even with the stock ROM. Not much I can do about it.
Hi Finless,
I got my tablet exchanged and flashed the new one today wihtout any problem. I only have an issue with the Market. I can't find the application I'm looking for (Sonos, Book Catalog, ...). I tried to follow your instruction but could not find the files you're mentionning. I'm using File Expert to browse the files but cold not find them.
Any idea?
Thanks and have a nice day,
Imkal
That is nothing to do with me. Bad translation in the stock ROM.
Robsta (In UK)
Cheers
Robsta
There are currently 1602 users online. 3 members and 1599 guests.
