[ROM] KIRk Out!! NEO X5 4.1.1_0117 {v 1.5}
    ok ladies and gents...this is my rom off of the minixforums, so I am posting over here at the freaktab as well. I have been warmly welcomed over here by the freaktab team and I just want to say thank you guys so much for the invite!
    CREDITS go out to Minix for making this stellar rom used as a base!!
    You will have the option to change kernels after my rom is installed or before or whatever you want to do. As always, make a backup first cuz I'm not responsible for you losing your stuff. Read below for more info.
    UPDATE (3/07/13):
    Most likely this weekend, after some testing of course, I will be changing the way we install the kernels for use with my roms, so look out for that!
    Well without further ado...here it is folks!!
    WARNING!!: I take no responsibility if you screw things up with your device!
    Current Release - v 1.5
    http://d-h.st/OAj
    Code:
    v 0.9a - Initial testing - thanks to those that tested!!
    v 1.0 - First release
    v 1.1 - updated apps and added Gameloft fixes
    v 1.2 - updated more apps and su & busybox
    v 1.3 - removed some apps and changed a few things.  sorry...had to re-upload cuz of some errors.
    v 1.4 - fixed my formatting scripts, so the system and data partitions will now be true ext4 format.  Updated some apps.  removed Grid Launcher.  fixed inverted Google Play store.
    [B]v 1.5 - removed some apps, added some apps, and updated some apps.  a few build.prop edits.  added libstagefright.so from Rockchip (you will have to install advancedsettings.xml manually if you want it).
    Changelog:
    What is has in it:
    Code:
    Rooted!
    Bloatware removed
    Gameloft fix  (credits Christian Troy)
    build.prop edits  (just minor ones so that most games work, but sorry...no Tegra 3 games.  Also these DO NOT work with Sopcast app)
    Apex Launcher (updated)
    Inverted Google Play - fixed and now able to buy apps  (credits Bad Seed Customs)
    Inverted Google Now - updated to newest  (credits B-Boy)
    Data added with some hopefully useful apps, don't worry they can be uninstalled
    Screen filter app
    init.d support  (if you guys want to add tweaks, I will add my own later, but for now...)
    YouTube 4.1.47 with full HD/full screen support
    QuickBoot (updated)
    updated apps including the newest SuperSU (updated again...sheesh!) & binary (again)
    Removed Root Explorer (sorry guys, thats mine!)
    Added Rom Toolbox Lite
    Added EStrongs File Explorer
    Updated busybox to newest 1.21.0
    Added Xbox gamepad codes (credits to Mow and the original xda thread)
    Removed Pandora, I added separate links for 2 different versions
    Added Inverted Dropbox - updated to newest (Bad Seed Customs at it again...those guys are the ish!)
    Removed Grid Launcher
    Added format scripts into the rom during flash through CWM
    Removed Screen Filter app (was causing video stutter)
    Removed CPU Identifier
    Added AdFree
    Updated inverted Google Play Store (credits Bad Seed Customs)
    Updated SuperSU & binary again!
    Added a few more build.prop edits
    Added libstagefright.so from Rockchip for hw acceleration (I left original there as well just in case), you will need to add advancedsettings.xml manually if you want it - see post #2
    What it doesn't have in it:
    Code:
    Full 1080p support...see the NOTE below
    5.1 Optical S/PDIF
    NOTE: if you want 1080p support, you must flash the new firmware first!! Then you have to reinstall CWM and then you can flash my ROM again! Or you can use my kernel flashing zip, but you use that at your own risk. Downloads are below in post #2.
    NOTE 2: Apex Launcher is the only home launcher that is installed, so if you want a different launcher, make sure you install another one FIRST before you delete Apex Launcher.
    Installation instructions:
    1) Copy the .zip to your X5
    2) Reboot into CWM
    3) Click on "Install zip from SD Card"
    4) Select the .zip and wait
    You no longer have to wipe, as my rom will wipe and format automatically...so still do a backup before you flash!!
    If you guys find anything, let me know. Also, if you want me to add anything or look into something let me know as well...thanks and I hope you enjoy!!
    [/B]
    Rockin' the 'ish outta Android!!
    KIRk Out!!
    XBMC:
    Delete the ".txt" off of "advancedsettings.xml.txt" below to make it "advancedsettings.xml". You will need to put it in your "sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/userdata" folder using a file explorer app. Viola!! Now koying's blacklisting is disabled
    refer to this thread for more info...http://forum.xbmc.org/showthread.php?tid=152005
    page 32 of the thread will have more advancedsettings options.
    NOTE: You must have installed the xbmc hw accel apk from xbmc.org and run it FIRST before you will see the "userdata" folder above!
    KERNEL FLASHES:
    IMPORTANT!!: PLEASE READ THE INSTRUCTIONS INSIDE FIRST BEFORE FLASHING THESE!!
    These zips contain the newest CWM recovery, so it is recommended that if you are coming from Finless's rom or Jazz's rom to flash one of these FIRST and then boot into recovery and then flash my rom. Like always, there is a disclaimer...don't blame me for ish if your device catches on fire!
    720p kernel:
    http://d-h.st/Lwq
    1080p kernel:
    http://d-h.st/94h
    MODS:
    White mouse cursor from 4.0.4 ICS build but with blue and black tip that I made zip flashable through CWM.
    http://d-h.st/g8y
    Lockscreen
    Enabled
    http://d-h.st/yH7
    Lockscreen
    Disabled
    http://d-h.st/6ew
    NOTE: These are only flashable through CWM. The lockscreen will need to be reset after each reboot!
    This is for JB 4.1.1_0117 only guys and I have only tested this on the 1080p kernel (though it shouldn't matter what kernel you're on), so please make a backup before flashing this...you have been warned!!
    CREDITS: All credits go out to Finless Bob for showing me how to do this mod and letting me use this for my rom, much thanks!!
    KIRk Out!!
      APPS:
      Inverted Pandora - with girl in background (credits Bad Seed Customs)
      http://d-h.st/N3I
      Inverted Pandora - girlfriend safe!! (also credits to Bad Seed Customs)
      http://d-h.st/sQo
      KIRk Out!!
        Re: [ROM] KIRk Out!! NEO X5 4.1.1_0117 {v 1.5}
        Oh man...sorry to the people using tapatalk, just now seen that the main posts are coming up black. Will fix when I get home.
        HTC EVO LTE with Tapatalk
        KIRk Out!!
          Hi, thanks for sharing.
          Will there have 5.1 Audio support for Neo X5 soon?
          Any diff from this X5_box_4.1.1_20130117_1080.rar to
          1080Kernel Flash+
          KIRk_Out!!_NEO_X5_4.1.1_0117_v1.5.zip?
            1080Kernel Flash+
            We will hopefully have 5.1 beta this month. Yeah there is a difference, look in my 1st post under what it has in it.
            KIRk Out!!
              Great News! Looking forward to the new firmware.
                update flashing with cwm works. But one problem I have starting the new rom the start screen from finless rom ist short coming up.I think I have some pieces from finless still on my box...how can I fully clean it.
                  For now use the kernel flashes I have in post #2, that will clear the boot animation.
                  KIRk Out!!
                    I did it now but the problem still exist. I flashed your kernel from Post2 via cwm. than made a factory reset , wipe cache partition, wipe dalvik cache.
                    did not boot the device. keep cwm open and flashed direct your rom. but after booting finless screen comes up.
                    any idea
                    thx
                    Herby
                      any idea
                      thx
                      Herby
                      The kernel flashers cannot be flashed with CWM. They need to be flashed with the RKandroidtool inside the zip file.
                      KIRk Out!!
                        I got an error "can't parse CPU features" at the opening screen of xbmc after adding advancesettings.xmlI am running version 13.0.1Alpha-1.Tried reinstalling the program doesnt work.Do a check and couldnt find the xbmc folder in the /sdcrard/Android/data/ directory though it has succesfully reinstalled the program.Any suggestion b4 I try to install back old version? Thanks.
                          Try the hardware acceleration version, but uninstall any previous xbmc versions first and then install and run it at least one time and that xbmc folder should now be there.
                          KIRk Out!!
                            Try the hardware acceleration version, but uninstall any previous xbmc versions first and then install and run it at least one time and that xbmc folder should now be there.HTC EVO LTE with Tapatalk
                            Thanks. My mistake that I am confused that I hv run this advancesetting in my phone setting instead.If I hv already installed the libstagefright.so and run the xbmc, now I copy the advancesettings.xml to the correct location with the right permission and then reboot the system. It should be fine, right?If there is problem, I will proceed to flash Finless ROM 1.0.
                              > which browser is onboard ?
                              > are icons / fonts / launcher (?) optimized for TV screen ?
                              > is modded Skype embedded (there are plenty of issues with Skype and rear facing camera instead of front...)
                              > is modded MX Player embedded (with DTS ffmpeg codec neon) ?
