Rom devs, would this be of any help to you guys?
    I own and have pulled out all the /system files from my Vizio google TV, yes I know google TV sucks but I bought one before I came to terms with it. There are a few things it did get right though, aside from being incompatible with XBMC, MxPlayer, Most of the playstore etc the launcher is great and would be nice for a tv stick & remote, think sidelauncher from market but bigger. also the TV player with PiP support apk, and google primetime which is amazing for TV programming. the thing is it depends on certain framework files from the GTV, I tried to shoehorn them into finless 1.7 and nothing really happened (hindsight thats prob the 2nd best thing to it working) but anyway I have all those files and framework if any of you guys wanted to mess with it just let me know.
    That´s sound great, can you please Share it with us ?
    If you want i can gave you Accses to the FTP Server.
    Kind Regards
    Neomode
      Re: Rom devs, would this be of any help to you guys?
      Kind Regards
      Neomode
      Neo I apologize it took me so long to notice your reply. Yes if you want me to ul it there I can. Otherwise I'll try to drop box it to you. And pm link
      Sent from my IdeaTabA2109A using Tapatalk HD
        Uploaded it to here:
        ftp.ebt-rauenstein.de
        user: [email protected]
        thanks a lot
        Neomode
          it's up there. have at it any questions about any of how the apps function on the gtv I'd be happy to help.
