Video player who can make playlist with files over network
My daughter watches a lot of shows that I use ES Explorer to open over the network in MX player..bad part is i have to start each one manually every 20 minutes...any apps to make a automatic playlist of avi files over the network? I use the imito mx2 finis 1.5Tags: None
Originally posted by shezzy View PostMy daughter watches a lot of shows that I use ES Explorer to open over the network in MX player..bad part is i have to start each one manually every 20 minutes...any apps to make a automatic playlist of avi files over the network? I use the imito mx2 finis 1.5
Originally posted by farhanito View PostTry BSPlayer,
It has LAN Mode and serves me quite well.
[N⁴][Motley][CarbonRom]
BSPlayer worked, two things I had to do to get it working tho.. after going to Lan Mode and searching for my PC server, I had to long single click it to change its display name from 192.168.100.1 to "slave" - other wise I could not get into the folders the PC was sharing.
Then I had to change the codec preferences to software from hardware to get the AVI's I had to work. without this change I would get only audio and no video for some files...hope this helps the community!! an awesome find for anyone looking to make a random playlist of a folder of AVI's from a network drive like I was. Thanks!!
HI , i just bought the Imito MX2 . It's working really well.
Btw , is there any way to play a slideshow/video automatically from this imito to TV set without any configuration in the first time ?
So when the TV turned on and switched the source into imito it automatically runs the slideshow
Thank you so much for the help
There are currently 1852 users online. 0 members and 1852 guests.
