Change mounting of sd to external_sd
    Is it possible to change the mounting of the SDcard to the External SDcard instead of internal sd.
    i have some apps that are not able to "browse" to the external SD, and internal is not large enough, to copy the data to (4.35 gig).
    Device: ug802, finless rom 1.8 720P default kernel.
    Mark
    I am feeling a bit stupid to anwser my own question.
    Yes its possible to change the mounting of the sdcard to the external sd
    to do this tou need to edit the vold.fstab in the /etc folder.
    these two lines mount the sdcard and external_sd
    dev_mount flash /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9
    dev_mount sdcard /mnt/external_sd auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
    just swap the fysical locations so they look like this:
    dev_mount flash /mnt/sdcard auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0
    dev_mount sdcard /mnt/external_sd auto /devices/virtual/mtd/mtd9/mtdblock9
    Save the file make sure the rights to read and write are still ok then reboot
    in my case a 16 gig internal SDCARD.
    in the attachment is a vold.fstab.txt already moddified file only rename it to vold.fstab
      you're my idol!!!!! thanks!!
        Just what I was looking for Thanks
          Thank you.
          Now I can use my old hard desks and make them usefull, but I noticed that the gta 3 and max payen games didnt work from hard desk. They only work when I move them to ext-sd by the directory bind so I think like these games need faster data readings.
          Other games work very well.
          Thank you.
            could be done on another device, is that I have a broken flash nand tablet.con
            and would need, the same but for the tablet, as it could be, thanks
              should be possible.
              the fysical adres of the nand and sdcard will be diffrent.
              but it stays the same
                Originally posted by DiSrUpTeR View Post
                should be possible.
                thanks
                had a problem with a tablet and nand flash, but in the end it was not the flash nad
                  I am feeling a bit stupid to anwser my own question.Yes its possible to change the mounting of the sdcard to the external sdto do this tou need to edit the vold.fstab in the /etc folder.these two lines mount the sdcard and external_sddev_mount flash /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9dev_mount sdcard /mnt/external_sd auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0just swap the fysical locations so they look like this:dev_mount flash /mnt/sdcard auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0dev_mount sdcard /mnt/external_sd auto /devices/virtual/mtd/mtd9/mtdblock9Save the file make sure the rights to read and write are still ok then rebootin my case a 16 gig internal SDCARD.in the attachment is a vold.fstab.txt already moddified file only rename it to vold.fstab
                  You may want to use /mnt/sdcard/external_sd instead of /mnt/external_sd. I mention this because some apps have problems with anything not under /sdcard and this allows you to access both without major issues.
                    Re: Change mounting of sd to external_sd
                    Great tip thanks
                      You can do this with a pendrive? Has anyone tested it?
                      Change SDCARD to USB?
                      Thanks!
                        I have UG802 Finles 1.8 720p and this setting does not work to me. Could someone upload function file?
                        thanks
                          Surely easier to use Foldermount from play store right?
