However it would be useful to have the ability to run the various Finless custom ROMs in a Virtualbox environment.
Is installing an MK808 ROM on Virtualbox possible?
I have a version of JB 4.1.1 working pretty well in Virtualbox by following the instructions below: http://www.keyables.com/2012/10/run-...irtualbox.html
However it would be useful to have the ability to run the various Finless custom ROMs in a Virtualbox environment.Tags: None
Hmmmm that is interesting!
But did you read what he had to do to port 4.1.1 including a custom kernel?
You wont be able to just run my ROM. But I may look into how to make a OVA file from a ROM. There must be some tool to do that or it is just a file system like a virtual hard disk? I need to learn that part first then I might try a port.
The version I installed is below.
vbox86t with Google Apps : androVM_vbox86t_4.1.1_r4-20121002-gapps.ova (installed with gapps-jb-20120726-signed.zip from Cyanogen)
It works with Google Play and the several Apps I installed all worked. Also it is rooted and SuperUser, as well as, Busybox work. It is a bit laggy, but not horrible. It isn't nearly as laggy as accessing my MK808 over a VNC connection. It can see the Internet, but it can't yet see computers on my LAN. I need to do some more reading to figure that part out. I will note that in Settings all of the developer options are greyed out.
Sorry I can't be more helpful.
Hey Bob, did you ever look into how to do this?
It would great to be able to test custom ROM's in Virtualbox.Randy
There are currently 2756 users online. 1 members and 2755 guests.
