Clone V2 UG802 connect VGA monitor
    Hello
    I have a problem and wanted to ask if you know fix.
    I have connected miniPC so,
    When I connect the monitor did not see anything on the screen, as if you do not recognize ... do you know if I can fix it?
    Thank you very much to all, greetings
    help me, please
      That HDMI to VGA is Active or Passive? If its passive it won't work. I supose that UG802 only has digital output to HDMI, and VGA only works with analogic signal.
      If that converter don't converts the signal, nothing can be done.
      On the other hand, the monitor that you are trying is FullHD?
        Originally posted by IhSack View Post
        Hello
        I have one of these and only got it working if the monitor supported 720p or 1080p using the custom rom. I don't know on a standard rom. Mines the orignal 802.
          For the truth is not ... What then could use adapter? thank you very much.
          Would this be worth?
          http://www.****.com/itm/281061234051...84.m1497.l2649
          The monitor is old but I have seen in the movies in 720p and 1080p without problem. Greetings and thanks.
            What he mean is your Monitor must Support the Resolution for doing that.
            This means on 720p your Monitor must have a Resolution of 1280x720.
            Neomode
              Neomode
              this is
                could someone enlighten me? thanks
                  Yes hello,
                  also i have buy me a hdmi to vga Adapter.
                  It works, but with the follow restrictions.
                  1.: You must use a 2 A / 5V Power Supply because the HDMI Adapter need 0,5A.
                  2.: Your Monitor must support the Resolution from the HDMI Adapter native !
                  720p --> 1280x720
                  1080p --> 1920x1080
                  3.: The Best is you use a 16:9 or 16:10 Monitor with support for 1280x720 for the best Resolution.
                  I hope thats help you :-)
                  Neomode
                    Thank you very much for the help.
                    I can not fix it ...
                    1. - I have a charger with these characteristics, no result
                    2. - Guess L22W-5 supports 720p, but donot like him.
                    3. - The resolution of the TFT is 1680x1050, the problem may be that, as I have the ug802 the 1280x720 resolution but nose like to change my tft
                      I have a Monitor that also is a 22" with your resolution.
                      Try to connect it to the PC and under HDMI Set the Resolution to 1280x720, shutdown and connect to your Monitor.
                      Your Monitor support 1.280 x 768 Pixel that is not 1280x720 may this the Prob :-(
                      I have a LG Monitor thats works.
                      What type of HDMI Converter you have ?
                      Neomode
                        Neomode
                        I have these two...
                        [IMG]http://i.****img.com/00/s/NTAwWDUwMA==/z/rxEAAOxyQBJREPSv/$T2eC16RHJGIE9nnWqyMDBREPSvYvI!~~60_12.JPG[/IMG]
                          The HDMI to VGA Cabel will not work. We need a Converter for the Signals.
                          The other Box you have look´s like my Converter.
                          Normely it must work. May the HDMI Converter get not enough Power from the Device.
                          Check your Converter if he get warm like mine.
                          Neomode
                            Neomode
                            Hello NeoMode,
                            Thank you for everything you are helping me. The charger does not warm, Apparently has this normal, I tried to feed him more chargers and a laptop but nothing more ... and nose that I can do ...
                              AW: Clone V2 UG802 connect VGA monitor
                              you misunderstood me, look if the HDMI converter gets warm. if not may we need to power up him a different way.
                              Neomode
