PROPOSALS ABOUT WIRELESS GAMEPADS !!! SOME QUESTIONS HERE
    Greetings and thanks for the forum It is very helpful
    So here is my prob: I have MK808B from geekbuying, ver.401j1_#26, android 4.1.1.
    All works fine. I just want to buy a wireless/bluetooth gamepad (under 20$ if possible) to play some neo.emu/gba.emu (emulators from Robert Broglia) and other emulators.
    If possible i want to buy a ps3 wireless sixaxis controller (clone)-like this http://dx.com/p/goigame-rechargeable...te-red-112272- to use it with that android application:
    https://play.google.com/store/apps/d...250cm9sbGVyIl0.
    The question is what controller is compatible with the above app? Are there any clones or should i buy the original one? The developer says that has updated bluetooth engine in order more fake controllers to work.. But he doesnt say which ones should work
    If any of you has MK808/808B and owns a relatively cheap wireless gamepad that works, please let me know
    Thanks!
    That might help
    http://www.youtube.com/watch?v=vei1qDv0kWE
    http://www.youtube.com/watch?v=Ze3YXXQdiHo
      Thanks but these videos dont say much
      Anyone knows if this gamepad http://www.****.com/itm/New-Recharge...item5aee81ce91 (or similar clones) should work with sixaxis app? They are clone ps3 sixaxis controllers, thats why i am asking..
        I can confirm that both the actual ps3 sixaxis with rumble and without work with the 808b, Id say buying a used ps3 controller and maybe going a few bucks over budget beats wasting money on something that does'nt. plus they are great controllers. I've used all the oid" emulators like nesoid genoid etc and they work great with it, also in mouse mode it's pretty handly for navigating the UI in general. it works with the internal bluetooth without any fuss. I use the dancingpixelstudios ps3 controller. quick rundown if ti's confusing
        -download sixaxis pairtool for windows, plug into usb, that is how you pair it, you get blue tooth mac address from the sixaxis app. if mac addresses scare you, think of them like ip's but for bluetooth.
        -alternatively you "should" be able to pair it by plugging it into the device I tried breifly and it did'nt work but I did'nt try other usb ports (mk808 is noted for being picky about which hole you stick it in, pun intended) if you don't have windows I'm sure you can find something that will change the "pairing" of a usb device, ie motioninjoy software can do it too.
        -touch profiles look a mess first time you check them out, they really are'nt too bad you just draw a big circle over where you'd "touch" it and they actually work really really well. If you or anyone has trouble with them I am pretty adept at making them and would be happy to by request
        -leave it in "android gamepad emulation mode" even if the emulator says "unknown" button when you setup your config it should still work.
        any other questions just ask
