What do I have?
    What do I have?
    Hi everyone, first post and as usual for these kinds of forums it's a question
    I have, what seems to be, an unbranded version of this
    For the purposes of rooting and installing a new rom can anyone tell me which version to use?
    Thanks in advance.
    What I can tell you so far.
    I flashed it with the Finless 1.5 rom for the UG802, it worked after a fashion with screen flicker, frequent crashes and no wifi.
    Tried again with the 1.7 rom, wifi now works but still have issues with screen flicker and frequent crashes.
    I've opened it up and I can't find a motherboard that matches it in any of the photos on here.
    It has the Rockchip RK3066, 2 Hynix 2gb memory chips and a Realtek RTL8188EUS wifi chip.
    It has a standard USB and a mini USB for power, with a USB button next to it, a micro sd card slot and a male HDMI connector. The only thing I can see on the motherboard that could be taken for a model number is MP-W6_V1.0
    Can anyone help narrow down which rom I should be using?
      Thanks in advance.
      That unit looks like the Smallart U1 with a RK3066 Dual-Core. Try flashing FW for the U2 !
        Thanks for the reply. The case is the same as the Uhost1 except my one has a sticker over the microphone port. It looks nothing like the Uhost2 but I might still have a go
          http://www.freaktab.com/showthread.p...-Rom-%28U1A%29
          Nah, didn't work, wouldn't boot. Thanks for the suggestion though.
          Ah well, the search continues
