Boot animation
    Boot animation
    Hi guys, I created a simple and clean boot animation. To apply it:
    - download this archive: https://docs.google.com/file/d/0B5ms...it?usp=sharing
    - to proceed you need to install "Root explorer" on your device from the Play store
    - copy (do not unzip) the file "bootanimation.zip" in the archive to the folder /data/local of your android stick
    - if Root explorer says the folder is mounted as read-only click on "Mount R/W" on top of the screen and repeat the copy procedure. Once you finish click on "Mount R/O" on top of the screen.
    - Reboot your device and you're done!
    Bob, if you think it is a good idea I would like to help to create a new clean and polished logo and animation for your next rom. Just let me know if you need some help!
    I couldn't edit the initlogo.rle file because I would need to repack (I guess...) and I'm not able to do it, but I'm willing to provide it too!
    Best
    AP
    My boot logo
    This is my boot logo for Freaktab...
      Hi guys, from the following link you can download a new boot animation that pays Bob some respect and is as red as Freaktab
      Same instructions as above. This is a 720p version, let me know if 1080p is needed!
      Best
      AP
      Preview:
        Best
        AP
        Preview:
        Looks good well done man 😊
        Sent from my Nokia Lumia 620 using Foroplex beta
        </form>
          Originally posted by Damo View Post
          Looks good well done man 
          Thanks! If the staff is interested I can elaborate and make it a lot better, let's just say "pro"
          Best
          AP
            Awesome work looks good which one is 1080p that I can use. I like the first one is it 1080p?
            Thanks and keep up the good work
              The first one is 720p only.
              From the following link you can download the red one for 1080p:
              Same instructions as before.
              Let me know if it works correctly as I can't test it!
              Best
              AP
                looks great, very professional
                i'm still getting bobs boot screen for the first 10 seconds of the boot, then it flashes and goes to the new one, is that normal, and is there something i can do to get rid of that so it starts with the new one and continues with the new one
                  Yes, it is normal. You can't get rid of it easily (I'm not able to do it).
                  Best
                  AP
                    Best
                    AP
                    nope, that is actually in the parameter file. We used to be able to modify the image in the parameter file and flash it on the mesmerize. (fascinate but on uscc) easiest way is the mess with parameter file before flashing but you do have a high risk of bricking.
                      There is nothing in the parameter file that defines any kind of boot image!
                      I explain the parameter file completely here:
