Can't get an MK808 (2207:300a) to list with adb
What windows version are you on and how did you install ADB drivers?
If on windows 7 you may have to make a ini file manually.
go into users>your user name> and create a folder .android if it is not there. Now in .android create a file called adb_usb.ini and in this file put this device ID 0x2207
I do not use windows, I run linux. I already have the lines in my adb_usb.ini file. They are also in my udev android.rules file. They are listed below. I seem to have another problem now though. My stick will not boot. I have not yet done anything to it but it just sits at the android bootsplash.
~/.android/adb_usb.ini
Code:# ANDROID 3RD PARTY USB VENDOR ID LIST -- DO NOT EDIT. # USE 'android update adb' TO GENERATE. # 1 USB VENDOR ID PER LINE. 0x1949 0x0006 0x0005 0x2207 0x0e79
Code:SUBSYSTEM=="usb", ATTR{idVendor}=="1949", ATTR{idProduct}=="0006", MODE="0600", OWNER="eshep" SUBSYSTEM=="usb", ATTR{idVendor}=="1949", ATTR{idProduct}=="0005", MODE="0600", OWNER="eshep" SUBSYSTEM=="usb", ATTR{idVendor}=="2207", MODE="0600", OWNER="eshep"
If it wont boot then the /data file system got corrupted. Common to happen with these units if you just unplug it while Android is up. Your going to have to flash a ROM to it now.
There are currently 2735 users online. 2 members and 2733 guests.
