(Yea its a 12V fan and im powering it through 5V, runs slow. But throws some air. so its ok.)
Alternatively one can also use a conventional USB fan u get cheap on **** (attached a pic of it too)
That's my setup basically... only to cool the device. Got nothing fancy apart from that :P
cheers!
ive seen someone use a cool 5V 25x25x7mm fan slapped onto the 808b. but that needs you to cut the casing of the device.
If you are keen you can use an external 12V power supply for the fan alone :P so much for a "Mini PC" lol
