NEOTV CR for MK802 IIIS Version 1.7 Neomode
If i'm correct this ROM will also work on my UG007(II). Im using MX1/2 Finless 1.7 right now. I use it mainly for XBMC with HW decoding. Everything works except for video with a resolution over 1920x816. Even if i lock the CPU to ~500mhz it still plays fine. So what i'm looking for is a ROM/kernel with the GPU overclocked (even just a little bit). I see you have the GPU set to 150Mhz, now i assume you have it downclocked, but i just want to check to make sure since i can't find the default GPU clockspeed anywhere.- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
- MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
- MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
Ah i see, so under load the GPU speed will be the same.
Can you tell me what is the default GPU speed for these devices is. I've seen overclock kernels with the GPU running at 466mhz and 500mhz i think, but what is the stock speed?
Thanks!- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
Ow that's quite high already. Was thinking it would be 250mhz or something like that. So an overclock to 466Mhz isn't even that much of an overclock.
By "trouble" i assume you mean heat problems? Because i've already put a heatsink on my device. Problem is there is no overclock (CPU or GPU) ROM/kernel available for my device yet!!!
Great job Neo
Hello Neo, I'm Simone from Italy, and I have installed on my Mk802IIIs your Rom
Congratulations first of all because it is very stable and smooth.
He is currently working with an ethernet adapter with integrated USB hub with a airmouse RC13 (the one with a microphone and speaker), all powered by one USB port of the TV ...
I think a lot of the power that requires this device is due to the wifi, in fact I also have a UG802 (with rom Finless 1.8) also powered via USB-TV and I also connected a webcam c-270!
However, in addition to the compliments, I would ask if it is possible (with some tricks), start the machine with the setting audio directly to "HDMI Audio" ... in fact, with a RC13 connected, the unit starts directly with the configuration "wireless audio", forcing each time to enter setup and change the setting.
Thank you,
great staff, great forum and great support ... keep it up!
Simone from Italy.
Droidmote and Kernel
Thanx for your work on mk802iiis
I have problem. I want to use Droidmote application. But how can i enable uinput.ko module?
I tried to enable on terminal emulator 3 times but no luck.
tried to see if there is support- 1) Open terminal emulator
- 2) su
- 3) cd /
- 4) cd dev
- 5) ls
droid mote server is running also on my phablet client is running but they cannot see each other. But strange thing is stock remote application is working.
Also have we got to change kernel with working wifi-bt is there any chance
AW: NEOTV CR for MK802 IIIS Version 1.7 Neomode
some times you must wait for a answer.
we are busy here.
Please send me a copy of the modules for you Device to [email protected].
Thx
Neomode FreakTab.com Developer
Originally posted by fatoyoko View PostLast day i wrote about problem but no one gives support or any idea thank you
That is outrageous!!! I would demand your money back!!! ow wait...- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
While I was flashing this ROM, the process aborted with a failure error on the step that checks what had been loaded.
Now the loader tool will never recognize the MK802IIIS at all when the reset button is depressed. Of course, when I try to boot the device it fails.
Is it possible to recover from this state, or is my MK802IIIS bricked permanently?
There are currently 2049 users online. 0 members and 2049 guests.
