Old full screen Youtube 4.1.47 apk
    I am very satisfied with my current setup i.e Finless 1.7a + Kizs Kernel 720p + CWM + XBMC HW Accl. The only problem I have is my youtube android app fails to connect every after few minutes of use. My wifi shows full signal and other apps works fine too.
    I want to try the older version may be it will solve the issue if anyone have a download link for I will be very thankful. I don't want to d/l from 4shared or Multiupload as I do not trust them untill unless it has been uploaded by you.
    GL
    D_A
    [MOD] YouTube 4.3.9 (v3b), 720p HD (over WiFi & 3G), screen off playback From XDA-Dev. I run this one on my phone and MK808 with no issue.
    TV Stick: MK808 // Tronsmart T428
    ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
    CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
    Recovery: ClockworkMod
    Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
    Phone: Samsung Galaxy Note II
    ROM: Whompasaurus v4.2
    Kernel: Persus
      Thanks! but it didn't worked, same loosing wifi connection every after few minutes.
        I sometimes have that happen at my house with the WiFi. Are you seeing the WiFi icon actually turn grey or disappear or are you saying YouTube is buffering or the video stops?
        If you are actually dropping signal, it may be that your router is changing channels because there are a lot of WiFi networks in the area and its trying to find a better channel. Or the radios could even be going out on the router.
        Try using the Android app WiFi Analyzer and see what channel has the best signal. Then you could use your routers WebGUI and force that channel to stick.
        EDIT: Just reread you OP and saw it may not be the actual signal, but go ahead and try that app and check your router just in case.
        Kernel: Persus
          I have the same problem with youtube too. Every now and then, the video won't display or will be too slow. I try 2 minutes later and there's no problem. This happens all the time. I switched from wifi to USB Lan but no difference. I am using Finless 1.7 on mk808. I would love to have this problem sorted out.
