Ployer MOMO7 Honeycomb Finless ROM V1.4 is Available!
"Forgive them as they know not what they do"Tags: None
- Stuck
Initial use showed that boot times are faster than the SDK and older ROM (2.3) as in about 25-30 seconds. The older ROM took anywhere from 40-50 seconds. I installed ROM toolbox to increase write speeds to the SD card and it also helped speed up the boot (when it prepares the TF card after the boot screen).
About 930MB available RAM from a previous 500MB. Some apps report 1GB RAM. No problems with the Android market.
I still haven't verified if it has a problem with battery use. With the previous ROMs battery times were about 4-5 hours. Have not used it extensively.
Quite happy with it as it's rooted!
Freeje
Well some programs report total memory available not's what used and left available. Some report what is available after the OS is loaded etc.
Hello
Originally posted by Finless View PostWell some programs report total memory available not's what used and left available. Some report what is available after the OS is loaded etc.
I installed the version of gingerbread and is working perfectly on my momo 7 but would very much like the version Honeycomb.
Thanks for your support I am very pleased with the gingerbread version available for you because it works much faster than the original version.
Originally posted by Lonty View PostSorry I can't connect nothing to usb, I have an otg cable but nothing
It's an hardware or software problem?
Sent from my SK17i using TapatalkPlease consider donating to purchase tablets for Finless Bob to continue his work. This will help in the creation of custom roms and build an even stronger development base for our community. Thank you for you support!
</form>
Try going into settings and enable USB debugging
</form>
There are currently 1701 users online. 1 members and 1700 guests.
