I just made a nice upgrade to our loved mk808 . I supouse that when its possible to unfold the beast to 1.6ghz or OC with two power supplies we are going to have heat problems. This is why I already made a modding on the case adding a heatsink.
I installed finless 1.7 and works really great , this man is saving the day to all . I´m not sure if I need to buy a second power supply 5v2a because benchmarks freeze if i put setcpu to the max. Is it ok if I connect the otg also to the usb from the tv ? Idk if that will burn or something, Im already using a power supply 5v2a .
[IMG][/IMG]
Thank you for your time.
