Preloaded games on MK808B
    My MK808B came preloaded with following games:
    Antarctic sports
    Dancing Beats
    Hurdling
    Ping-Pong
    Sprint
    Tennis
    When I try opening these games, it shows message "connecting ..." then quits after three tries. Any idea how can I connect using lefant mouse.
    I have lefant air mouse and description of its listing shows these games.
    Any idea?
    HI
    Seems the MK808 factory is working with a game supplier in china, and they want to push their airmouse, and then they pre-installed those games.
    i have asked them, you have to use the following air mouse:
    to play those games.
    other air mouse won't work.
    hope this help.
    thanks
    Looking for developers
      Thanks..
      Any idea what is this menu below wifi keyboard?
        Dear Lion,
        This is the Google Pinyin Keyboard for entering Chinese text. I guess you'll not be using it much, so you can disable.
        cheers!
          Thanks everyone for pointing me to the right direction.
          I sourced the game/remote code from lefant to register and use the remote on MK808B.
          Its so fun to use these somatosensory on MK808B Yay!
            I have RC11 remote is there a way i can play the games with it?
              These games are someto-sensory games and can only be played with remotes that have G-Sensors. I am not sure if RC11 has G-sensors.
                Yes RC11 has gyroscope i dont know if that is not enough ?
                  Nope that's not enough, you need G-sensor as well.
                  I am using this:
                    Originally posted by geekbuying View Post
                    HI
                    hope this help.
                    thanks
                    I have this Air mouse (from geekbuying) and its does not work!
                    When i start one of the Games it says "Registration fail".
                    Any ideas?
                    Thanks in advance.
                      Any ideas?
                      Thanks in advance.
                      Try any of the apks from here:
                        http://gamehall.kalazhu.com/netxeon/arm/
                        Hi
                        Its not posible to Download the Files. I always get:
                        E:\Temp\Psstthrj.apk.part could not be saved, because the source file could not be read.
                        Try again later, or contact the server administrator.
                        If i rename the Downloaded File to Psstthrj.apk or Whatever.apk and try to install this i get:
                        There was a problem parsing the file
                        I tried this with all the Games and all the Browsers i have (FF, Chrome, IE. All uptodate.).
                        Strange thing is that the *.apk.part files seems to have the right size (MByte).
                        If you can download them or if you already have them on your HDD can you please upload them somewhere else or send them to me my e-mail (please PM)?
                        Thanks in advance.
                          I am able to download the files, anyway, try to download from here:
                            http://d-h.st/yoJ
                            Thank you for your time and effort.
                            Same issues with the new download location, that's when i decided to deactivate ESET SmartSecurity 5.2.9.12.
                            What can i say, now it works without problems. I will test an replay if they work.
                            Thanks again.
                              Ok. I was able to install all of the Games successfully but if i start them my http://www.geekbuying.com/item/Air-M...le-314301.html 3D Air Mouse is not recognized. I get a Fault message in Chinese with an X an then the Games exit to "Desktop".
                              I tried it with all the Games, same result.
                              I tried the 3D Air Mouse plugged in the OTG an the Full size USB Port. Same result.
                              Does anyone has the same 3D Air Mouse from Geekbuying?
                              Thanks in advance.
