CWM Recovery and Gallery of Flashable zip files by Leolas
    WHAT IS “ClockworkMod” RECOVERY?
    ClockworkMod recovery is one of the most widely used custom Android recoveries that is available for most mainstream Android devices.
    ClockworkMod, abbreviated as CWM, is a popular custom recovery for Android phones, tablets and TV Sticks, developed by Koushik Dutta (Koush), a well-known name in the Android development community. ClockworkMod recovery allows you to perform several advanced recovery, restoration, installation and maintenance operations on your Android device that aren’t possible with the stock recovery, and is one of the most common ways used to gain root access, back up device data, install custom ROMs, kernels, themes & mods, and more. However, for anyone new to Android customization and hacking, some of its options might prove to be a little bit confusing.
    WHY SHOULD I INSTALL “ClockworkMod” RECOVERY?
    -Reboot into recovery to flash any flashable zip compatible to your device
    -You can back up and restore your data/firmware
    -You can do maintenance like formatting, factory reset, wiping cache delvik cache etc
    -You can get root access, back up device data, restore device in case of any accident etc
    -You can install custom ROMs, kernels, themes & mods.
    HOW TO INSTALL “ClockworkMod” RECOVERY ON YOUR MK808/MK808B?
    For most devices, ClockworkMod has a dead simple installation process. This method does require you to fully root your device in order to be installed but once rooted (in our case, Bob already did that for us) installing it is as simple as re-naming the zip to “update”, copy on your SD card and stick in our device and reboot, done!
    Here is download link: http://androtab.info/clockworkmod/rockchip/rk3066/
    HOW TO BOOT INTO “ClockworkMod” RECOVERY?
    Bob already included in his ROMs an app called “Reboot” a green color app. Just click that app and it will give you an option to Boot into recovery.
    That was a brief introduction, now what we can do with our device? Leolas and Bob made some incredible work for development of this device. Here are the some extremely beneficial zip files which can make your device really useful.
    Flashing ROM
    http://www.freaktab.com/showthread.php?4023-Do-you-want-to-flash-your-rom-using-cwm-recovery-take-a-look-here
    Kernel Flasher (Post # 16)
    libstagefright.so
    http://www.freaktab.com/showthread.php?4021-cwm-recovery-zip-for-the-new-libstagefright-so&p=54888#post54888
    More zip coming in shortly! stay tuned.
    All credit goes to Leolas and Superman Bob, I am just gathering this info to one place.
    You keep this up and I might have to make a new FAQ / Guides forum
    FYI, these guides really are not just MK808 specific! They can be used generically for all TV sticks for the most part.
