My question is, has anyone been able to extract the EHomeMediaCenter app from the Andoid Mini PCs, so that it can be installed on other android devices?
As an example: My wife uses her Samsung Galaxy Tab2 7.0 in the kitchen. it would be great if her tab acted like an Android Mini PC with the EHomeMediaCenter app installed on it.
The reason I am asking for/about the EHomeMediaCenter app, is because, other DNLA/UPNP rendering apps have limitations and aren't as simple at the EHomeMediaCenter app, as a play to point (render) in our home.
Any and all answers would be helpful even if you recommend an alternative app that is just as simple, flexible and able to handle all media types. Although EHomeMediaCenter isn't as feature rich as XBMC. XBMC for Android does not play all media types as smoothly as EHomeMediaCenter does. Plus as a play to point XBMC bells and whistles aren't needed.
Thank you in advance!
Crooked8s
