Archos 80 Cobalt 900 supersportROM (2 feb 13)
This is based on Archos's ICS firmware.
Features
- defaults to uk
- root
- some bloat removed
- busybox and init.d support
- play/market fixes for more apps in google play
- 2 Gig apps/user space
Instructions
- flashing will clear all your data so you may want to backup first
- remove any external sdcard as otherwise it may be formatted
- download and unzip
- start the ROM tool
- put the tab into bootloader/flash mode * and install drivers if required
- click erase idb
- on completion flash the ROM
- first boot will be to recovery, select reboot (vol keys navigate and power selects)
- this boot will take a little longer but you then have a freshly setup tab
At this point you will have stock recovery (required as my CWM will not format the sdcard on this tab) I you want clockwork recovery then download from the link below and:
- extract the zip and copy to the 900supersportROM folder
- start my ROM tool
- clear all the check boxes but recovery
- double click on ../900supersportROM/recovery.img and edit to ../900supersportROM/CWMrecovery.img
- Flash
CWMrecovery download
* to put the tab into bootloader/flash mode either
- with the tab off hold vol - and connect the USB to the PC after a few seconds (could be as much as ten) the tab should be detected by the flash tool.
- from a rooted tab with a terminal emulator. Connect to the PC by USB then on the terminal emulator you can enter
reboot bootloader
cifs support can be added as follows if you have already added CWM recovery
instructions
- download the cifs.zip to the internal sdcard, do not extract
- reboot the tab to recovery (i've included Petrus's reboot app in the system tray)
- from recovery select 'install zip from sdcard' (scroll with vol +-, select with power)
- select 'choose zip from internal sdcard'
- navigate through the folders etc to find cifscwm.zip and select
- scroll through the nos and select 'Yes -Install cifscwm.zip' and let it do it's stuff
- select go back and then reboot system now
Finally a couple of words of thanks to
- t-bon3 for supplying the tab at the price tesco sold it
- the team here at freaktab, especially Finless without whom I would not be cooking ROMs
