Pipo M3 3G RileyROM 1.0
    Here is the link to the download section for the Pipo M3 3G RileyROM 1.0:
    This is the first release of a ROM for the Pipo M3 3G tablet.
    This new ROM is rooted with ext4 file system, init.d support, 2gb user app space.
    Please look at the ReadMeFirst file for details.
    I do not have an actual M3 tablet to test, however I used the M5 as a test platform, and the ROM works fine on it. Anyone with an M3 3G please test and provide feedback.
    Thanks to: Tattman65 for art work, Snakekiller for UI Mods, Petrus for reboot app, and Finless/900Supersport/Neomode for lots of guidance.
    If this is the first time you are flashing one of our ROM's, you may encounter some challenges in installing Windows drivers. Please download this First Time User Guide to help you throught he process:
    Download
    Randy
    Sv: Pipo M3 3G RileyROM 1.0
    Any one tested?
    From my daycruiser
      It worked on my M5 with the M5 kernel, but no one has posted results on an M3, yet.
      Randy
      Randy
        I have a this tablet I can test when I have time. Is there a change logg?
        From my daycruiser
          No change log, sorry.
          Randy
          Randy
            Ok can you write little about changes and which image it's based on
            From my daycruiser
              This rom is based on the most current firmware posted on Pipo's site. Since I don't read Chinese, I can't tell if there is any information as to what they changed or fixed in their kernel.
              I just downloaded it, rooted it and added all the usual stuff. Line I said, I did test the rom on my M5.
              Randy
              Randy
                install driver
                heeelp trying to install driver for this device
                but cant get it into flash mode
                anyone know how.its rooted before whit xp mashine.
                trying now whit win 7 64
                regrads wikings1
                  First make sure USB debugging is turned off.
                  If your pc is looking for the driver...install it manually with the driver included for your OS.
                  You might need a different USB cable.
                  Try those things. Once the flash tool sees the tablet as a Mass Storage device, just click the boot to flash button on the flash tool. Once it connects as loader...let it sit there for a few seconds before you erase IDB.
                  Good luck.
                  Randy
                  Randy
                    Good luck.
                    Randy
                    Thanks flashing its easy when you now how report in the morning about rom regards wikings1
                      Working perfectly thanks feels like a new tab recommend this regard wikings1
                      From my daycruiser
                        That is GREAT NEWS!!!!
                        Thanks.
                        Randy
                        Randy
                          Hope there is Riley whit android 4.2.2 soon regards Wikings1
                          From my daycruiser
                            Believe me...I check the Pipo site every day for updates.
                            I thought at first that these tablets might be similar enough that firmwares could cross over to other Pipo tablets...but alas there are too many specifics built into the kernels. Especially going from 4.1 to 4.2. And now 4.3 is trickling out on the Nexus tablets.
                            As soon as I get an upgrade from Pipo I'll update the RileyROM for this tablet.
                            Meantime, any thoughts on what else should be added in the next ROM?
                            Randy
                            Randy
                              Black market hehe joking
                              From my daycruiser
